Home > Puma (Tdci) > Puma Chassis - TD5 Chassis |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5024 |
There are some differencies between the puma and td5 chassis and some major ones between the 300 and puma ones.
Suspension i understand is different too - but nothing major in that regard, just spring rates/loads i understand they changed on the 90. Mike |
1st Jan 2010 9:07pm |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Suspension (at least on the 110) is the same as the Tdi and Td5. The only difference being the front springs are no longer handed and are now both the same as the passenger's side of the previous models. Strangly if you then go to HD springs in the front they are still the same old handed ones. 110 2.4TDCi
110 300Tdi LROCV ::: AULRO.com |
2nd Jan 2010 12:11am |
555SUB Member Since: 21 Feb 2009 Location: Shropshire Posts: 17 |
So from your replies fitting a Puma engine and gearbox would fit into a TD5 110 Chassis.
Dave |
2nd Jan 2010 1:38pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Would fit,, with some re working of the engine / gearbox mounts, gearbox tunnel, etc,, Make sure you get the engine loom and ecu etc,, and the bonnet California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
2nd Jan 2010 6:29pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1567 |
Got different camber angle on tdci and shocks are new. The engine sits different, ashcroft had trouble getting the auto box to fit due to engine angle.
2nd Jan 2010 11:51pm |
