![]() | Home > Technical > Alarm trying to tell me something? |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 ![]() ![]() |
2007 110 SW Puma TD4 - no electrical mods except installation of a TrailAir
When I lock the car with the fob, it appears that the alarm arms. I get three flashes from the indicators, and the rapid flashing of the red dash light for about 10 seconds, followed by the normal flash every 10 seconds or so. However, when I unlock the car with the fob, I get no flashes from the indicators, and what appears to be a code of some sort from the red dash light, a series or rapid double flashes over a period of 15 seconds or so. Is it me that is being paranoid that the alarm is trying to tell me something? or do I remember correctly that the indicators should flash when the alarm is deactivated, and that there is no particular flash pattern from the red light? Thanks for any light that can be shed on this, Jon PS of course it might not be the alarm, but the immobiliser or some other part of the landrover "security" system....... |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18028 ![]() ![]() ![]() |
It's trying to tell you that the handset battery is on the way out
From another thread:
Perfect!
Thanks - however it is strange I couldn't find the other thread with the search function. Jon |
Ah yes, but to search for "handset battery", you have to know that the alarm is trying to tell you that the handset battery is dying......
Jon |
Just need to know where to look..... ![]() http://www.defender2.net/forum/topic16861.html?highlight=fob http://www.defender2.net/forum/topic2114.html?highlight=fob If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
