Home > Wheels & Tyres > Puma OE Alloy wheel nut replacements |
There's no reason why alloy wheel nuts should wear out and need replacing every five years Either something very unusual has occurred or you've bought the wrong socket. Darren
12th Sep 2013 1:48pm |
rleslie Member Since: 10 May 2012 Location: Ellon, Aberdeenshire Posts: 128 |
cheers Darren
So can someone confirm its a 28mm socket before I go and buy one! cheers |
12th Sep 2013 1:52pm |
Simon27 Member Since: 30 Oct 2012 Location: East Lothian Posts: 131 |
It was 27mm for the Boost alloys on my 2009 model.
12th Sep 2013 1:57pm |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
27mm however swollen nuts are comon im afraid
12th Sep 2013 2:35pm |
Really? Never heard of it before Darren
12th Sep 2013 2:43pm |
I led to believe it’s our old adversary bi metallic corrosion between the nut and cover
12th Sep 2013 3:08pm |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
It would seem not that uncommon. Land Rover vehicles appear frequently, but also others.
https://www.google.co.uk/search?q=swollen+...ent=safari LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
12th Sep 2013 3:36pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
For some reason I involuntarily crossed my legs when I read this post. BM52
12th Sep 2013 3:58pm |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2664 |
Yep, the nuts do swell.
I've got a bag of them in the garage to replace them when they swell too much for the 27mm socket... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
12th Sep 2013 4:54pm |
Cheers Guys.
So I take it I just buy the same ones again? No after market ones that don't rust and don't swell.... Thanks |
13th Sep 2013 7:32am |
rosscomax Member Since: 07 Nov 2010 Location: Fochabers Posts: 12 |
Hi,
my ones are the same, bought a new set from ebay but they are crap, stainless covers fall off after fitting!! Have you found anyone who supplies solid ones?? |
15th Nov 2013 7:53pm |
Best thing I found is to soak the nuts (before they are corroded ) in thinned waxoyl or any good any rust fluid overnight then quick wide off then let then dry ...seems to help stop them corroding inside under the cap
15th Nov 2013 11:48pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila, SFO, Amsterdam Posts: 676 |
Apologies for reviving an old thread but I have need to know regarding these things.
When I got my truck from the previous owner, I negotiated the acquisition of his boost alloys and corresponding wheel nuts as well. He reluctantly gave them over on the condition that I hand over the original steel wheels, the wheel nuts for the steel wheels and for the spare, and the 27mm tire wrench as it was useless to me. Upon fitting, the alloy wheel nuts he gave me were all 28mm rather than 27mm but the guy who put them on apparently used a 12 sided spanner rather a proper 6 sided socket hence deforming some of the wheel nut covers. Upon looking for replacements, I found out that even alloy wheel nuts with stainless covers for the Defender are 27mm and not 28mm! Does this mean that all the wheel nuts that I was given were all swollen?! In any case, my options now are to either acquire wheel nuts with stainless covers or the solid steel wheel nuts for alloys. I was told that while the wheel nuts with stainless covers look nice, the solid steel ones last forever. What do all y'all think? Thanks. |
10th Jul 2015 6:59am |
OEM Nut is 27mm the 28mm is a get around
Just buy new 27mm nuts I'm sure Mal (K9) will provide the relevant link to a great aftermarket supplier |
10th Jul 2015 7:04am |
