Home > Puma (Tdci) > Scraping noise from back end on overrun, diff?
Jimbob
Wales 2015 Defender 90 Puma 2.2 HT Corris Grey
Only noticed it the other day when I turned the radio off, can hear like a faint scraping noise coming from the back end of the car when slowing down or going downhill engine breaking, sounds like a brake disc/ pads out put their all fine and it makes no difference if the brakes are on or not? Noticed a bit of an oil leak from what looks like the front oil seal so need to check the level too what oil needs to go back in? Ill check it and top up first but in the mean time any more suggestions as to what it could be?
Cheers! Smile 2009 Defender County Hard Top (gone 😞)
1990 200tdi defender off roader
2015 Defender XS Hard Top (awaiting delivery 😄)
Post #265592 11th Sep 2013 12:34pm
geobloke
Could be your transmission brake shoes rubbing.
The oil leak from the diff flange is a common problem, you can buy a kit to fix it.
http://www.ebay.co.uk/itm/BEARMACH-DISCOVE...460d16b06d
Post #265611 11th Sep 2013 1:34pm
According to the fitting on that link it say's that won't fit a 2.4 Defender? Perhaps it's wrong?
My 90 does the same as this but only relatively rarely. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #265790 11th Sep 2013 8:56pm
