Home > Technical > traction control switch
stevetd5
Australia 2002 Defender 110 Td5 SW Alpine White
Hi Is anyone able to give me a few tips about instaling a switch to disable the traction control on a td5 2001/2 defender. Thanks
Post #265445 11th Sep 2013 4:04am
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
From memory you only have to push the foot brake quickly 10 on starting the engine and the tc is switched off
Post #265451 11th Sep 2013 6:49am
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
Mine was done by Land Rover, they cut the 12v feed to the TC unit under the seat, ran a two core cable up to the dash and fitted a switch. Mines a 2007 but I'd imagine it 's the same principal.
I changed the switch to a Red carling switch.
The ABS won't work with the TC isolated.
Hope this helps.
Post #265470 11th Sep 2013 8:02am
Naks
Re: traction control switch
Why would you want to disable TC!? Confused
Simplest way is to remove the ABS/TC fuse.
However, be aware of the consequences if you are involved in an accident: your insurer can refuse cover on the grounds that you disabled a safety feature --
Post #265518 11th Sep 2013 9:30am
It's specifically to do with sand driving, where TC can be more of a hindrance than a help. Darren
Post #265533 11th Sep 2013 9:51am
Naks
If you need to disable TC when driving in sand, you are doing it wrong.
When driving in sand:
. Deflate tyres to 1.2-0.8 bar
. Engage CDL
. Choose correct gear and ensure you have momentum to clear the obstacle
See:
In all the sand driving I have done, TC has rarely intervened, and when it does it's usually when I'm doing something silly, like power-sliding across the face of a sand dune Whistle --
Post #265539 11th Sep 2013 10:00am
stevetd5
Thanks I will try the 10 brake application idea but the switch is on the list.
Post #265559 11th Sep 2013 10:29am
stevetd5
Post #265560 11th Sep 2013 10:31am
stevetd5
Post #265561 11th Sep 2013 10:32am
walfy
Sometimes the TC can be a hinderance in sand. A couple of years ago several of us went to Morocco, 2 Puma 110, 1 TD5 110, 1 Landcruiser and my D3.
Going up a track off the beach my D3 sailed up with no issues, the TD5 110 sailed up but the 2 Pumas had issues, tyres aired down did nothing. Fuse being pulled solved the problem.
So in that instance a switch would of been perfect.
It was about the only time my D3 outperformed the 110's in the sand Rolling with laughter 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #265572 11th Sep 2013 11:09am
stevetd5
Just curious if I do the 10 brake application trick does it reset when next ignition is turned on or do you need to apply brakes agian to reset or is this a permanent switch off. I don't want to try it and then have to go to a dealer to get the code reset ( no diagostic aquired as yet). Thanks
Post #266201 13th Sep 2013 4:20am
kirk
United Arab Emirates 2009 Defender 110 Puma 2.4 SW Blenheim Silver
I tried this brake method, but found that TC turns on again after you exceed +/- 10mph. I couldn't keep it switched off.
Post #266203 13th Sep 2013 5:43am
kirk
Post #266204 13th Sep 2013 5:43am
yobbie
Yes it comes back on when you restart Thumbs Up
@kirk I've never had the T/c come back on until restarting the vehicle.
Post #266213 13th Sep 2013 7:05am
stevetd5
Hi, My t/c resets at about 20kph also. Must be an ecu variation. Looks like the switch is on its way.
Post #266605 14th Sep 2013 1:04pm
