Home > Maintenance & Modifications > Winter mods - Heated Seats & Mirrors
excossack
For winter I am planning on retro fitting heated seats and heated mirrors to my TD5
When fitting heated seats, do you have to remove the original seat base and back covering in order to fit the elements? Or can you slip the elements between the cover and the foam?
Heated seats will be on two switches (Passenger and Drivers side.) and the Mirrors, will be on one switch.
I have seen a few suppliers for both, but are there any to avoid (Send PM if you prefer) 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #265161 10th Sep 2013 12:36pm
geobloke
For the seats you are going to have to remove the covering completely before setting the heat pads in place.
Something on my list to do.
As for the mirror they are well worth the effort Thumbs Up
Post #265185 10th Sep 2013 1:22pm
excossack
Is this an awkward job or are the base covers clipped in ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #265194 10th Sep 2013 1:49pm
The Genuine TD5 heated seat switches are really expensive from Land Rover, if you want to go that route look out for used ones on Ebay.
Alternatively use Puma ones which are a 10th of the price but will have to be fitted on their sides in the TD5 dash.
Puma:
TD5:
Post #265210 10th Sep 2013 2:26pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
Here is a post I wrote when I fitted mine.
http://www.defender2.net/forum/topic17504....eated+seat
There is another link within it to a guide for removing seat covers
Hope this helps
Jim
Post #265250 10th Sep 2013 5:01pm
excossack
Puma:
TD5:
For some reason, I got no pics Sad
I was thinking of sticking with Carling's as you might have spotted I've ordered a few off you Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #265307 10th Sep 2013 6:53pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Would Discovery 2 or Freelander heated seat switches fit a TD5 Defender dash?
Post #265317 10th Sep 2013 7:16pm
Interlet
United Kingdom 1998 Defender 110 300 Tdi HT Alpine White
If they are the same shape they will. It all came out of the same, rather ancient parts bin! 1998 110 300Tdi White Hard Top
Post #265323 10th Sep 2013 7:29pm
