Home > In Car Electronics > Views on Tablet for mapping
v40mav
I've been using a mixture of phone and sat nav with an old net book linked via bluetooth to Mem Map - This has worked well for years but sadly the netbook had died -
I'd love to use my ipad but I only have a wifi version so no GPS ?
Whilst I'd love to get a iPad mini with 3g - I cannot justify this at this time - ( too many other toys to get )
I have been looking at 7" Android tablets - and the 2 that seem to rate highly are Samsung Galaxy Tab2 or Nexus 7
Both can be bought relatively cheap - -
Anyone using these for on board mapping - likely to be Mem Map and Viewranger
or any other recommendations
Hugh Defender 110 County SW
Disco 3 HSE
Freelander 2 HSE - SOLD going back to a car
www.lothian4x4response.org
Post #263279 2nd Sep 2013 11:41pm
Eduardo
I use as a GPS backup a Samsung Galalxy Tab with Sygic GPS software with good results (also used to see movies and ear music and other uses).
My 1st choice is my old Garmin 60CSX due the free maps availability.
Cheers Eduardo
Post #263284 2nd Sep 2013 11:55pm
Eduardo
Double post... Eduardo
Post #263285 2nd Sep 2013 11:55pm
VeeTee
Netherlands
Why not use a bluetooth GPS linked to your iPad? Cheers, Vincent
MySite
Post #263314 3rd Sep 2013 7:46am
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I bought a Samsung galaxy tan 7.7 for this very purpose.
Larger screen size than the dedicated Satnavs I could find, but sits nicely in the middle of the dash without obscuring too much of the view. I originally wired it in to also feed music to the head unit, but have never bothered using this.
Use copilot Satnav software, works well for on road. Have mm tracker to use my memory map maps off road but not really used that part in anger yet.
Post #263321 3rd Sep 2013 8:17am
I didn't think bluetooth GPS worked with wifi-only iPads? Darren
Post #263322 3rd Sep 2013 8:20am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
Bluetooth GPS receivers do work with iPads, I have various satnav apps on mine. However, in order to be able to use them you have to jailbreak the device and get the Bluetooth stack and interface from Cydia. I'm not sure if a Bluetooth stack is available on the AppStore. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #263328 3rd Sep 2013 8:38am
Ahh. That sounds worth investigating, thanks. Darren
Post #263338 3rd Sep 2013 9:28am
rustyboxx
Have a look on iphonehacks.com. It all depends which iOS you're running, the latest iOS isn't jailbroken as far as I know but earlier versions should still be able to be jailbroken. If you're thinking of doing it let me know and I'll give you some tips and point you in the right direction for various tweaks needed. Thumbs Up 2015 90 XS CSW TDCi - Beautiful
Post #263348 3rd Sep 2013 9:54am
Ooh, yes please. I have an original iPad running, from memory, IOS 4.something. Darren
Post #263356 3rd Sep 2013 10:29am
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Me too, I bought the 7" version which is now at £129 Shocked add a defender case for £35 and you are good to go!
I got mine mainly for walking as I have the car sorted, and its a far better size screen than the dedicated satnavs out there. The memory map android map is free (as are most of them) and I already had the latest maps. Installed them on an sd card I had and works out of the box.
One benefit of the android setup (apart from the price) is that you can turn off the 'assisted gps' which you can't do on the ipad/phone setup. This means that the gps is using satellites all the time rather than initially searching for a position using wifi and/or phone masts as the ipad/phone is. That way if you are in a low phone signal area the iphone takes ages to get a fix and where the Samsung Galaxy tab uses the satellites and fixes much quicker (and holds onto it better) When I take it out of the pocket so see how lost I am its on target virtually straight away and works perfectly in woodland which my old Garmin didn't.
You can cobble together a setup to use a non 3g ipad but if you want to use it out of the car your stuffed a bit (and you probably will). If you already have an ipad then maybe that's a plan, but the way I read the opening post - you wanted recommendations between the Samsung Galaxy and the Nexus, rather than other options.
As far as the choice between the two - I had the same choice and on the face of it the Nexus is a better specced machine (newer version of android, more pixels, a bit faster etc ) The Samsung downloads the newer version when you turn it on so no worries there. The Samsung is a bit cheaper I believe, but the most important issue for your intended use is that Nexus owners are reporting issues with the gps. I have read this on tech and review sites - I don't know what the issues are but Google are 'looking into it' . I guess the majority of users don't ever use the gps apart from to see where the nearest Nandos is so probably not an issues for them, but for our usage is fairly crucial the gps works without issue.
So its a no brainer really - get the Samsung before they sell out, the 7" is perfectly adequate and has worked perfectly for me on several test trips. The screen clarity is find, especially bearing in mind the fairly low resolution of the os maps when zoomed in) Obviously you can get the more expensive 'note' model but no real need if you just want a nav system. And make sure you get a hard case - preferably an Otterbox Defender as the tab is very thin and I think would break in bits if you dropped it. The otterbox has the benefit of a hard screen cover you clip on, so no issues chucking it in a bag. Some of the other hard cases leave the screen exposed (under a thin screen protector) which defeats the object of encasing the rest in a hard case in my book.
If you plan to use it in the car then simply get one of the mounts I bought for £25 and you are good to go. (plus there's no problem picking up gps with the heated windscreen)
Have fun
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #263392 3rd Sep 2013 2:15pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
FYI - you don't need to jailbreak ipad for GPS.
Get a Garmin Glo
Works out of the box, and picks up US and GLONASS GPS nets. Not the cheapest at ~£80 but works well
Post #263399 3rd Sep 2013 3:07pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Is it possible to link your iPhone with your ipad and use the maps on there? hope that sounds right Confused Cogito ergo sum
Post #263428 3rd Sep 2013 5:00pm
alfajock
United Kingdom 1989 Defender 110 V8 Petrol CSW Bonatti Grey
I tried mapping on my ipad but it didn't seem to go any faster Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff
Post #263517 3rd Sep 2013 8:40pm
v40mav
Not keen on the idea of jail breaking the iPad. What does this actually do to the iPad. Defender 110 County SW
Disco 3 HSE
Post #263553 3rd Sep 2013 9:54pm
