Home > In Car Electronics > Dash Switches
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Dash Switches
Hi,
I'm looking to install some auxiliary lighting on my td5 110, my hazard light, fog, rear wiper and rear washers are on square switches located on the top of a centre console which also holds the radio. There are 2 blanks next to these switches and I would like to use these for the aux lighting. I have done the searches but cannot find these switches. Any help would be greatly appreciated.
Regards
Bows
Post #262815 1st Sep 2013 9:51am
The proper auxilliary lighting switch is part no. YUG000540LNF but it's become very expensive in recent years:
http://www.lrseries.com/shop/product/listi...WITCH.html Darren
Post #262819 1st Sep 2013 10:00am
Bows
Great work, thanks, your searching skills put mine to shame. £53.56 inc the vat!! Ouch!! Arjay Motor Factors it'll be I think. It's extremely difficult to justify the best part of £55 for a simple on/off switch!
Thanks again for finding the item though. Thumbs Up
Post #262823 1st Sep 2013 10:25am
Post #262826 1st Sep 2013 10:38am
msb
United Kingdom 2004 Defender 90 Td5 PU Coniston Green
Have a read of this....
http://forums.lr4x4.com/index.php?showtopic=84901#entry728827
...with a little bit of work you can use the £5 switches.
HTH
Mike
Post #262948 1st Sep 2013 7:26pm
Bows
I've had another idea, is there any reason why I can't get a second rear fog light switch and mount it upside down? It'd almost look identical to the front fog switch but cost £9 and not £55.
Post #265412 10th Sep 2013 10:40pm
Rear fog light switch is a 'momentary' one not on / off Sad
Post #265414 10th Sep 2013 10:44pm
Bows
Foiled again, any other suggestions? thanks
Post #265734 11th Sep 2013 6:25pm
mk1collector
Heated seat switch
Post #265735 11th Sep 2013 6:27pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
Latching relay with the rear fog switch - press on, press off.
Post #265885 12th Sep 2013 6:54am
TD5 heated seat switches are silly money.
I did think of some sort of latching relay but couldn't think how to make it work, could you put up circuit diagram please ?
Post #265887 12th Sep 2013 7:03am
appaloosadude
I think would be correct, with one output left clear. I imagine there is a better alternative, but brain function is not yet 100%!
Post #265889 12th Sep 2013 7:10am
ericvv
That same switch also exists in a different version. The looks are identical, but it is a latch on / latch off switch.
When my dealer installed my front fogs, he used that switch for the fogs in the empty space on the Puma.
It is wired up so that the fogs will only come on together with the parking lights or low beam, go off again with high beam. But if you leave the switch in the latch on position, when switching back from high beam to low beam, the fogs will come on again. Surely you could use that switch which probably is cheaper for any aux lamps. It is the same function principle as the now expensive YUG000540LNF. Don't have a price or part number, but ask a decent LR dealer.
Below is a picture with at the left side the rear fog light switch which is like Go beyond explains, and on the right side is the switch with the same looks, but latch on / latch off type.
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #265896 12th Sep 2013 7:23am
mk1collector
Use a tdci heated seat switch but replace the cap with the blank cap. All you need to do is drill a small hole for the light and you can scratch any picture you want into the blank cap. I think paulmc on here did a write up on lro about it a while back but I can't find it now Crying or Very sad
Post #265917 12th Sep 2013 9:20am
udderlyoffroad
Not sure about the switch p/ns more modern landies have, but a Durite p/n 0-728-02 latching relay will take a momentary switch input and give you proper on/off functionality.
 Real trucks don't have spark plugs
Post #266016 12th Sep 2013 3:55pm
