![]() | Home > Maintenance & Modifications > Headlining - home made option?!! |
| Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478
could always reuse the original material if its good enough that is, if its dirty just clean it. Remove the staples and then remove the trim and re stretch it over and re staple. Use automotive spray glue to help it stay up there
www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
| Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435
Thanks Killer, will the material come away from the board part? I've not taken it out yet to have a good look to be honest
But yer basically it will just peel away, once the headlining is dropped you will see the staples on the back holding the trim on remove these and its very easy from then in www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
| Myers Member Since: 07 Dec 2011 Location: Wiltshire / Sailisbury Plain Posts: 156
Hi
When the roof lining of my 90 started to come away I used this stuff: http://www.vanguard-conversions.co.uk/product_p/vel.htm Really easy to use, 6 sq Mtrs for the whole roof of a 90, so as yours is a truck cab half that. I do recommend on using the glue they sell as well |
Thanks for the replies, I think recovering the original might be the better option, the 28 years of grime looks well ingrained!!
The van guard looks to fit the bill. Thanks again |
| All times are GMT |
