Home > Td5 > Td5 running cool / overcooling
Martin
Site Admin
Just noticed yesterday on a motorway run that the temperature gauge was reading lower than normal.
Yes, I'm aware that Td5s normally read just to the left of vertical (and it always has until yesterday) but this is significantly further round to the left than that.
I'm thinking that this can't be anything else but a duff thermostat? Seems to warm up OK though Confused
Pic just after getting off motorway:
  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #262358 30th Aug 2013 10:23am
excossack
I do have a document showing the resistance values for the temp sensor if thats any help? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #262369 30th Aug 2013 11:22am
When you are off the motorway is the temp ok?
Have you checked the coolant level?
With the engine running, gently unscrew the air bleed screw on the coolant hose .. Hopefully some water will come out ...
Check your viscous fan?
Post #262370 30th Aug 2013 11:55am
Lou Sparts
Mine always runs about there summer and winter changing the thermostat made no difference Sad 2005 Td5 90 XS
Steve
Post #262477 30th Aug 2013 8:29pm
Martin
Site Admin
John, the data would be handy, yes please - can't find any info in RAVE.
Done all the usual checks but nothing showing up Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #262581 31st Aug 2013 10:22am
landy andy
Are all other gauges, lights ok? Could it be an earth issue? My temp gauge will twitch when I turn something else on or off.
Andy
Post #262582 31st Aug 2013 10:25am
james975
Scotland 2000 Defender 90 Td5 HT Epsom Green
I had the same problem.
It was the earth under the drivers seat next to the ecu.
cheers James
Post #265745 11th Sep 2013 6:54pm
jimbob7
Mine sits about there.
Post #265747 11th Sep 2013 6:57pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
my temp always sits there, and when i have been booting it for a small while or towing up a hill it does raise slightly, it must be ok, coz my kenlow coincides with that and starts when the needle has gone up a fraction.
Post #269762 27th Sep 2013 2:51pm
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
It could be a broken spring in the fuel cooler? Just seen this on a 99 disco.
Post #269803 27th Sep 2013 6:02pm
