![]() | Home > Technical > Front 90 Diffs |
| noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196
No I only ever seam to break rear ones, had 2 in the 57plate puma. fronts have never given me problems I have had drive flanges replaced at service but noting else, exploded a cv on my P38 they are supposed to be bullet proof not !! If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
Yes done two front ones. Both good quality units.
I was asked if I pulled away from standstill on the road enthusiastically. Do you Andy |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
This a worrying thread.
If you 'pull away enthusiastically' won't the traction control protect the drive shafts/diffs? I beginning to think ABS won't........ BM52 |
No nasty abs witch craft for me
From what I understood, it was due to one front wheel spinning when pulling away with some lock on. I changed it for a four pin diff, and all been good since. Just normal case of standard diff's not being great design/build. Andy |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034
Given that the 2-pinion diff is considered by LR to be not strong enough for the 110 and 130 I have never understood why it's considered ok in the 90.
Having seen the way my 110 diff broke up I am surprised we don't hear of more failures. Worth bearing in mind that an Ashcroft ATB is cheaper than a standard diff from LR, and is properly built by people who care (unlike a LR diff). |
| william8 Member Since: 03 Apr 2013 Location: Motherwell Posts: 259
I had one go (20k miles 08 plate 90) No load no nothing. Reversed out of the drive put it in 1st and bang. Didnt even drop the clutch as i was in no real hurry.
Fitted ashcroft ATB.... MUUCCCHHH better, less diff slop Considering buying one for the back too just before it lets go. I ended up about £400 for Ashcroft ATB install including new bearings etc as you dont want all those wee bits in about the bearings. William |
