Home > Maintenance & Modifications > Keyfob mod
Alexke
Belgium
Keyfob mod
Took me 2 hours and some sweat but finally I have them both in one!
http://www.benl.ebay.be/itm/170990175204?s...1497.l2648
the blanc key in this one isnt compatible , I modified it myself
http://s21.postimg.org/ap295obpf/foto_1.jpg
Lovin it! Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #261345 26th Aug 2013 12:41pm
rustandoil
I like that Thumbs Up
Good work Bow down
Post #261369 26th Aug 2013 2:29pm
dgardel
Italy
Experiment done last year, but it touch the light switch when low beam ON..................
and need to change the "blade" with the old one (using a dremmel) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #261383 26th Aug 2013 3:41pm
Alexke
Belgium
at first it didnt touched it but it was close
for good sake : I bended the light switch a couple of degrees and it has way more clearance .
didnt use old blade , I went to local key shop and they made the blade for me , I cutted the end. Discovery 4 SDV6 Landmark
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #261396 26th Aug 2013 4:39pm
ninacrawley
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Orkney Grey
Any playing with the electronic fob required?
Thanks
Post #262999 1st Sep 2013 9:56pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Any chance someone could do a quick tutorial / take a few pics of this mod please? My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #263041 2nd Sep 2013 7:48am
K9F
It states on the advert.....
IMPORTANT NOTE - It MUST be glued together… There are no ‘snaps’. There is no way around this.
Can you still change the battery when required? Looks a cheap, viable and interesting mod! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #263047 2nd Sep 2013 8:32am
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
I have a Freelander in addition to my Defender so I bought one of these keys for it. (I already have an all in one for my Defender from Dgardel) Easy enough to build up and get the key cut but I only used it for a short time before going back to the original key. It felt cheap when you were using it as there was a lot of give in the case when you were turning the key to start the car.
Also the rubber buttons used to pop out of position when in use. (A drop of superglue would probably have fixed this) What was strange was the fact that the central locking started playing up with the new key even although it was the original key electronics that was inside it.It would take several attempts to lock and unlock on occasion so I took the new key apart and rebuilt my original key and since using it have not had a problem.
Taking the new key apart pretty much destroyed it as the superglue was doing its job well! You would have to apply just a few dabs of glue if you wanted to be able to take it apart at any point in the future. I will probably buy another all in one for the Freelander the same type as the Defender key I have.
(Footnote) I bought my wife a similar flip key for her Tigra which was slightly different in that it screwed together and had a heavy chunky feel to it. However she came home from work the other day with the key snapped in the ignition as the blade had snapped at the thinnest part where the roll pin holds it in place. Not a big deal to get the broken bit out as there was enough left to get pliers on and enough left for her to turn to start the car!
The key was probably about a year old but now back to the spare key. Dgardels all in one key has a quality look and feel to it and I have had no problems with it. It did cost several times more than the cheap flip keys so it `s probably a case of you get what you pay for!
And before anyone tries it no you can`t slag me for owning a Freelander! I`ve had it 7 years and its been a great car! (TD4)
Post #263063 2nd Sep 2013 10:26am
