![]() | Home > Maintenance & Modifications > Fitting a volt meter |
| bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248
I connected mine to the switched live to the radio.
Seems to work OK Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6045
Seems sensible to me. I was thinking of fitting a toggle switch so I can get the voltage of the 2nd battery as well. 1999 Defender TD5 110
| JWL Member Since: 26 Oct 2011 Location: Hereford Posts: 3443
I wired mine directly to the batteries so I can read the state of them both via a simple on/off/on switch. I went to the batteries to eliminate any voltage draws through the loom. I can also watch the charge voltage when the engine is running.
and I guess that way you can also check the status of the batteries without having to turn the ignition on. 1999 Defender TD5 110
Yep
Sounds like a plan to me. 1999 Defender TD5 110
| All times are GMT |
