Home > Maintenance & Modifications > Jaguar XF V6 with Auto box
Kittyhawk
Has anyone fitted the above engine to a defender? I have a low mileage salvaged vehicle at my disposal and want to fit it to a 110. I also want to fit in the auto box too. Is this possible? What would be the disadvantages?
Post #259534 18th Aug 2013 7:43am
BigRuss
its the same V6 diesel engine they fit in the Disco4's and RRS's so yes it has been done Thumbs Up Russell
2011MY 110 XS USW Black
Post #259547 18th Aug 2013 8:57am
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
The diesel V6 in the XF is the TDV6 used in RRS and Discovery 4, so a couple have been fitted. It will however be the Jag version, not the LR one, so stuff like oil pick up in the sump won't suit extreme angles. My Disco 'best bits'
Defender 110 XS CSW 2013
Post #259548 18th Aug 2013 8:59am
Kittyhawk
Thanks guys. Not worried about oil pick up, not looking to extreme off road. What about the jag auto gear box, is that an easy fit?
Post #259550 18th Aug 2013 9:04am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
It won't be cheap conversion and the main company simtek want abt 6k to make it run in your environment but I have heard of a lot of people with big problems using this solution also I doubt dry much you cold se the auto box with out spending huge money
Bas did this n a 2.7 tdv6 but used the manual 6 speed from a disco and had a plate made to make it fit the transfer case
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #259553 18th Aug 2013 9:10am
Kittyhawk
I've just seen that nemeoverland use the same engine in one of their conversions Thumbs Up
They also fit auto boxes but for big money. I'm sure there must be a cheaper alternative?
Post #259555 18th Aug 2013 9:14am
Porny
Site Sponsor
It can be done - I'm just starting a V6 engine conversion for a customer (but using a 6 speed manual box - rather than auto).
All the conversions I've seen so far use the Simtek ECU...
I've experimented with the bodylogic system for a customer (in a very well know Off Road Race Car), and was far from impressed. To the point where I would not put my name to the work, so it got given back.
It is a very basic alpha n system, and not designed to run a complicated modern diesel engine.... not properly and to an OEM standard. The system was shocking, and didn't even have proper fault detection, which lead to a dead turbo charger. For a man in his garage it might be passable, but no proper torque strategies, no proper cold start control, no proper boost control - the list goes on. The ECU is more suited at a basic petrol engine.
Also, all the auto versions I've seen use the massively outdated and pointless 4 speed ZF auto.... 4 gears on an engine with such a capable torque and power band is useless. Everyone runs the gearbox and the engine on two completely separate ECUs - but then need to integrated together to give a smooth, controlled and safe drive.
As mentioned by Disco Stu....
To do it properly I would run the Land Rover spec sump - it's a lot narrower, and would improve engine packaging (along with retaining its off road capability). To swap over isn't hard - all you need is the sump, pipe work and to clock one of the turbo's slightly (same turbo on both engines, but compressor is rotated slightly on the LR application (very easy to do - just needs a split pin changing).
Also, you would not easily be able to use the Jaguar Gearbox - as the casing is different to the LR application.
The Jaguar has a flange for the prop shaft - where-as you want the abilty to bolt an LT230 transfer box onto the back (so a LR box would be needed) - and I can supply a adaptor plate to do this.
Then you just need a ECU solution and wiring - which is all very do-able Wink But not that cheap. In short there are a couple of ECU's that can be used - one is a bosch motorsport ECU - but this is £££££££'s, the other is an open source/platform ECU, or the third is the option which I use... The nice thing is mine is it's an off the shelf ECU... i.e. no waiting months if you ever need a replacement - the ECU is not normally used for this application though (but conveniently can control V6 and V8 diesels).
It will also work properly over CAN to control the TCM (transmission control module) and the instrument cluster on a Puma. Time just needs to be taken to set everything up properly.
For example - don't think you can just run on a Disco 4 ECU calibration copied into the ECU - to get it driving correctly the engine will need a good few hours of dyno , rolling road and on road testing to get it performing correctly. A Defender weighs a tonne less than a Disco 4, so this needs to be taken into account (both Engine and gearbox calibrations will need setting up).
Also, depending on what you are doing with the rest of the powertrain (axles, diffs etc) the calibration will have to torque limited at certain loads/speeds/in gear etc to stop blowing everything up.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #259620 18th Aug 2013 2:46pm
Kittyhawk
Wow, fantastically detailed response. Thanks
So jag auto box is useless. What's a rough cost for the set up you mentioned?
Post #259678 18th Aug 2013 8:13pm
DiscoStu
Don't worry about the cost - imagine the Defender at the end! Cool Wink My Disco 'best bits'
Post #259687 18th Aug 2013 8:53pm
Kittyhawk
Unfortunately with 4 kids (all girls at that) cost is all I seem to worry about!! Shocked
Post #259709 18th Aug 2013 9:42pm
Sell em' Whistle ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #259738 18th Aug 2013 10:24pm
Kittyhawk
Hahaha, I'll actually be paying to get rid of them too!!! Not looking forward to paying for 4 weddings!!!
Post #259742 18th Aug 2013 10:48pm
Pickles
Porny...Unreal knowledge there.
Geez, a bit different from the old days when ya'd just pull the old engine out, fabricate new engine mounts, maybe a bit of an exhaust, drop the new engine in...and ya're away....a lot different these days.
Cheers, Pickles.
Post #259747 18th Aug 2013 11:08pm
Porny
Site Sponsor
Depending on specification - and what functions you wanted pricing would start from about £6500 + vat for the wiring loom, integration, ECU and all of the final calibration set up.
Add to this the transfer box adaptor, cooling pack (intercooler + rad pack) and exhaust system... Your going to be up to about £10,000 + vat before fitting. And then a £1000 ish for a used Disco4 Gearbox.
But for this you would have about 240bhp and 600Nm - matched to a 6 speed auto gearbox. And it would drive like an OEM conversion (so would be like driving a Disco 4/RRS).
There are lots of options you can have - including paddle shift, stop/start button, a sport button option etc... and more power. But this will affect cost.
Really with this much power you would need to look at brake and suspension upgrades.
Cheers, Pickles.
Bordering on being a Geek lol.... (actually, think I have crossed that border).
People don't realise how far technology has advanced - especially diesel technology....
Ian IRB
Post #259767 19th Aug 2013 7:42am
Kittyhawk
More fantastic info thanks. Time to start looking in the piggy bank. Think I'll do it whilst converting a 130 into pick up too
Post #259770 19th Aug 2013 8:06am
