|  | Home > Puma (Tdci) > puma immobiliser / remote / starting problem |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233      | Check the connections to the 10AS alarm (Green) box thats on the bulkhead behind where the speakers are for water and corrosion.
 Pete | ||
|  17th Aug 2013 2:09pm |
| WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935      | Have you got 2 remotes, and do they both have the same effect?
 If it is a 2010my, then the batteries should have been changed in the remotes at least once according to the Service Manual. Something simple to try. If both remotes act the same, then as Pete says, it is probably something to do with the alarm unit or connections.  LANDYWATCH   Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php | ||
|  17th Aug 2013 2:48pm |
| stephenj Member Since: 23 Jul 2012 Location: richards bay Posts: 2      | Thanks for the suggestions. No sign of corrosion  (second remote at work so did not try that)and stranger yet left overnight and come the morning everything back to normal... remote works alarm activates deactivates landy  starts no problem at all. Even worse  in a way as do not know when will happen again | ||
|  18th Aug 2013 6:05am |
| couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830      | Did you change the batteries. When mine were getting old, the alarm had random behaviour.
 Cheers Simon | ||
|  18th Aug 2013 7:57am |
| ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817      | Same experience here.  When locking the car with the remote suddenly the orange turn signals would not come one anymore as indication that the alarm was on.  The red LED would still start flashing, but when subsequently unlocking the car with the alarm, the red LED would for 15 seconds keep go on and off in an erratic mode.....   Always could start the engine and drive off though.   Seems those thngs happen as a warning of low remote battery, and yes, replaced the battery, and all was back to normal promptly.  Replacing battery by one fresh out the blister is first thing to try   You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw | ||
|  18th Aug 2013 9:14am |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
