Home > Td5 > Front Flaps
johnnyd
Front Flaps
Hi All
Noticed yesterday a rubber/sponge seal seems to be loose within the drivers side flap/vent (do they have a special name ?)
Is the flap easy to get off? and does the foam/rubber ring attach to the bulkhead or to the flap ?
JD 2008 TDCi 2.4 XS CSW
Post #258103 12th Aug 2013 11:09am
landy andy
Seal fits to the flap, not the bulkhead, understand that after market ones are not as good as main dealer parts.
Andy
Post #258105 12th Aug 2013 11:12am
johnnyd
I was just going to araldite or superglue the ring back on to the flap ? I guess the flap is easy to remove ?
Post #258108 12th Aug 2013 11:15am
mk1collector
Open the flap then from outside the vehicle underneath the flap there are two ten mil nuts to undo, then lift up (I'd leave the top hinge bolt in place if your just re-glueing
Ray
Post #258113 12th Aug 2013 11:22am
johnnyd
Thanks Ray
Post #258114 12th Aug 2013 11:24am
mk1collector
Thumbs Up the two bolts attach the vent opening lever inside the vehicle so don't lose them Mr. Green
Post #258116 12th Aug 2013 11:27am
johnnyd
Thats why i wanted to ask here, any gotcha's etc Wink
Post #258119 12th Aug 2013 11:29am
