Home > Td5 > s220
ironman19
1997 Defender 90 300 Tdi HT Belize Green
s220
Hello....
I have a 2004 90 x Tech td5. I am on a mission to beat will.i.am at his game. Laughing
Has anyone fitted a s220 turbo to their td5?
Post #255369 1st Aug 2013 6:22pm
Porny
Site Sponsor
I've fitted lots of them...
As they were my turbo (along with the whole other range of bolt on VNT replacement turbo's), developed for me by Turbo Technics. BAS is also able to sell them (as we agreed this at the time) - but he is the only other authorised distributor. Everyone else that sells them is mealy buying them off myself or Pete. No one else had any input in their development, testing, tweaking, etc.
And if they say otherwise they are lying.... and this does show up in the set up at times.
This is a great turbo, and with a dual channel limiter box, high quality intercooler and exhaust make for an excellent conversion with matched mapping.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #255547 2nd Aug 2013 8:17am
What's so special about this turbo Ian?
Post #255563 2nd Aug 2013 9:21am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
comes in a BIGGA BOX.... Laughing , from fitting them myself, and after Ian has set them up, the delivery of power is there from low down revs ( I think this is correct, i'm no engineer , but no doubt his lordship will be along later to explain in the way he does......all big words to me... Whistle ) Putting Dreams on Drives at JLR Solihull..
Post #255571 2nd Aug 2013 10:13am
Porny
Site Sponsor
The S220 turbo has a different compressor wheel, compressor housing and exhaust wheel to the smaller S208 turbo (which has the same max flow as a standard turbo - just with much nicer characteristics).
Basically more flow (volume) without increasing boost.
Ian IRB
Post #255596 2nd Aug 2013 11:38am
Oh OK. so better or worse than the VGT i've got from you? or just "different"??
Post #255645 2nd Aug 2013 3:52pm
Porny
Site Sponsor
Just for different applications...
The S208 (as per yours) is designed for mildly tuned Td5's and offers a massively improved pick from low RPM and mid range. When the VNT mechanism is fully open, the max flow of the turbo is very similar to that of a standard fixed geometry turbo. However, what it does do is offer much better drive-ability. However, max BHP will not increase over a standard turbo. What it will do however is change the torque curve and characteristics - which is where the biggest difference comes.
However, the S220 - with the the larger compressor wheel/housing - allows more flow for a given boost pressure.
The S220 was designed for greater power outputs - and improve performance. Commonly classed as a 'hybrid' - if you are after increased power outputs (typically 180bhp and 430Nm upwards) this is the turbo for you - but still with great low range and mid-range drive-ability. The most I have seen is 235bhp and 535nm running this turbo and other modifications.
Ian IRB
Post #256024 3rd Aug 2013 8:11pm
ironman19
fitted the turbo.....WOW......what a difference. The sound is amazing and teh power is something else. Would highly recommend to anyone who wants, as Jeremy Clarkson puts it POOWWEEEEERRRRRR Laughing
Post #267136 16th Sep 2013 10:32am
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
hello, what is the total cost all in and delivered for this turbo??, Also what pressure does it run with, i may be putting an order in[img] Whistle Whistle Whistle Snigger [/img]
Post #269503 26th Sep 2013 6:24am
Will.I.AM
another question, what is the difference between the 208 and the 220, i have reading up a bit and it seems in theory that the 220 will have greater volume of air but will have a great lag than a 208. what would give the overall best performance and least lag, without pressuraing above 1.2 bar?
Post #269952 28th Sep 2013 4:25pm
