Home > Maintenance & Modifications > MSS or Mantec rear window guards?
G4sweep
Germany 2012 Defender 110 Puma 2.2 XS CSW Santorini Black
Hi,
I'm after a pair of the rear window guards for the 110, however, I am wondering if anyone can share any knowledge as to how much drilling is required for fitment? On the MSS site it states that pre-existing fittings are used to secure said guards and can't for the life remember how the Mantec ones were fitted in my G4 USW.
Any advice as always would be grately appreciated.
Craig. Sweep
2.2 110 XS SW
Gone;
08 D3 XS
BN55 WPV G4 4.4V8 D3.
O7 G4 Mongolian Recce 110 USW
Post #254140 28th Jul 2013 6:38pm
mattlab
England 2009 Defender 110 Puma 2.4 USW Galway Green
mantec ones are drill and screww LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #254142 28th Jul 2013 6:48pm
G4sweep
Hi Matt,
Cheers for the quick reply. Do you know if any drilling to the body itself is required or just through the trim?
Apologies for the bone question! Thumbs Up
Craig Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #254147 28th Jul 2013 6:55pm
mattlab
i only fitted the one rear window guard on the door as its a usw and drilled 10 holes, 4 up each side and 2 at the top around the glass frame. i would have thought the rear quarters and side window one would be the same but dont know for sure, if they were only in the trim they would have no strength LIFE`S TOO SHORT TO DRIVE A BORING VEHICLE
Post #254151 28th Jul 2013 7:04pm
G4sweep
I thought exactly that regard the fitting to trim only, however, on Mantec's website the photo seems to show at least the top fixing points to attach to the trim. I don't know what's behind the trim as I haven't looked (yet) to see what the guard could attach to vehicle body wise.
Cheers again for the info, I do remember the rear window guard on my G4 USW having screws into the door body.
Craig. Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #254160 28th Jul 2013 7:27pm
Thor
United Kingdom 2002 Defender 110 Td5 CSW Bonatti Grey
I have the Mantech/G4 ones in mine they were already fitted when I bought it. The top of them screw to the trim as said above but the bottom the bolts go through some box section, which you slide in some threaded metal plates. I guess you have to drill the holes. Strong people are harder to kill and generally more useful!
Post #254162 28th Jul 2013 7:39pm
G4sweep
Cheers for the info Thor, much appreciated. The ones in my old USW were Mantec prototypes and it being a USW I guess we're/are different than the SW variants. I guess it's just down to the make / style I buy now!
Cheers. Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #254180 28th Jul 2013 8:02pm
Romadog
Get MSS ones as they are bolted in on the inside.
Post #254195 28th Jul 2013 8:40pm
geobloke
I have the MSS guards in my 110 and really rate them. If you are interested I can post up a selection of photos I took when installing the guards?
Incidentally the interior style guards are awesomely useful when camping/overlanding...
Post #254295 29th Jul 2013 8:24am
TACK
I made my own.
Only needed to drill 1 hole near the door
[img]https://www.defender2.net/gallery/albums/userpics/10578/normal_DSC04380.JPG[/img
Post #254296 29th Jul 2013 8:32am
TJ101
Tack,, Read the title,, Window Guards !!
I have MSS internal ones,,
No drilling required, bar the back door, 6 seft tappers holding the guard in,,
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #254299 29th Jul 2013 9:00am
G4sweep
Cheers for the photos Tack & TJ101, much appreciated. I just need to get my backside in gear and buy some now before I go away. Geobloke, photos would be gleaming if its no dramas?
Cheers once again Thumbs Up Sweep
2.2 110 XS SW
Gone;
08 D3 XS
Post #254419 29th Jul 2013 5:17pm
Defendermatt
United Kingdom 1989 Defender 90 Other SW Bonatti Grey
TJ101 Do you need to remove the rear seatbelt brackets to fit the MSS quarter window guards? 1989 90 4.3 V8
2012 L405 OF
2014 D4 HSE Lux (SOLD)
2015 90 HT (SOLD)
@d9o.mf
Post #962040 17th Aug 2022 7:34pm
bear100
I’ve got the full flatdog cages and upper and lower shelves, great kit with no issues so had their rear window guard, used small rivnuts to fix in place 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #962061 17th Aug 2022 10:57pm
Defendermatt
I have the MSS ones but can’t work out if you need to remove the rear seatbelt brackets in order to fit them, or if they go on top. I can’t get them to fit either way. 1989 90 4.3 V8
2012 L405 OF
2015 90 HT (SOLD)
@d9o.mf
Post #962074 18th Aug 2022 6:33am
