![]() | Home > eBay & Bargain Spots > 110 double cab hannibal roof rack |
josh_a_miller Member Since: 08 Oct 2012 Location: Bath, Zomerset! Posts: 101 ![]() ![]() ![]() |
http://www.ebay.co.uk/itm/271234387086?ssP...1438.l2649
on the hunt for one myself, unfortunately i've been informed that it wont fit a 110 station wagon ![]() Price is still low and not long to go! 1988 Defender 110 County 300tdi Chancer |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17944 ![]() ![]() ![]() |
Who told you that it won't fit? I would have thought that it would fit fine.
Certainly the (very similar) Patriot rack is the same regardless of model. I have a full-length Patriot on my DC that came off a SW. With the Patriot all the mounting hardware is interchangable, and assuming that the Hannibal is similar parts are available I would have thought if you bought two extra pairs of gutter-mount legs to use at the rear it would be fine. I don't understand Sparkylee's comment that the legs are different lengths on the DC and SW - they are certainly the same on the Patriot rack, and the roof height is the same on a DC and SW, so why would the legs be different? |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
It's the length of the bars that are shorter on the DC one compared to the SW as they only reach over the 2 doors not the height that differs
But yes I've always thought if I change from DC to a SW I'd keep my rack It's good to be back from the dark side DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Ah, OK, I understand now!
On the Patriot rack for an SW, there are four leg assemblies, each consisting of two actual legs attaches to a long bar which sits in the gutter, ie, two assmblies (four legs) per side. The DC standard version has two leg assemblies (one eash side), each assembly consisting of 3 actual legs attached to an even longer bar to sit in the gutter. On my conversion, after discussion with Patriot, I have SW front legs and a single individual leg on each side, which works just fine. On that basis it should be possible to fit a Hannibal DC rack to an SW, provided that you don't mind muying some extra legs and don't mind the result being non-standard. Thanks for the extra info, Sparky! |
Thanks for the input guys, its pretty local to me so would be ideal.
It was Frogs Island that informed me. 1988 Defender 110 County 300tdi Chancer |
If the Hannibal rack has twin ladders supporting the rear then won't the offside one foul the spare wheel if it's on the door? I guess it would work without the spare there, but that'd be pretty unusual, so that's probably the basis of being told it won't fit. Darren
Very good point! 1988 Defender 110 County 300tdi Chancer |
