Home > Td5 > Salisbury axle
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Salisbury axle
Hi guys, my 110 has the Salisbury axle, and it has quite a bit of back lash, does anyone no how to adjust this if at all, I'm hoping its the same as a conventional diff, your thought appreciated,
Not long now for Billing hope this weather holds out,
Mark
Post #249656 7th Jul 2013 7:13am
No, the salisbury isn't quite the same as a normal rover diff.
To adjust the backlash you need to remove the rear cover, unbolt the bearing caps, use a compressor frame thing to slightly squeeze the casing to release the diff unit. then shim it up, refit, measure, remove, re-adjust etc etc until the correct backlash is achieved.
quite a faff.
Post #249660 7th Jul 2013 7:51am
tazmarkuk
Thanks Diesel Jim,
Looks like I need to sort out specialist to do the job
Post #249883 8th Jul 2013 6:58am
It's do-able at home; usually when the diff/casing gets worn, then the diff assy will come out with a couple of pry bars.
Obviously to refit it perfectly would need the use of a spreader or compressor, but a friend and I did my axle (when I fitted an ARB locker) with a huge G clamp he had.
To fit the locker it was in fact easier just to remove the whole axle, access was waaay better then.
Post #249969 8th Jul 2013 2:55pm
