Home > Td5 > Hi Low switch
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
Hi Low switch
according to the hawkeye my 110 is in low when in high and visa versa, will this effect the driving as low is reduced throttle??
the plug on the switch only goes one way, so can i just cut and swop wires or is it a hawkeye giving incorect data www.Equi-Trek-Tregaron.co.uk
Main Dealers for Equi-Trek and Brian James Trailers
Post #248443 2nd Jul 2013 7:23pm
Nanocoms also show this back to front thing. don't know why.
You'll know what way around it is.... when in low range, and the switch contacts closed, you'll get little throttle reponse until about 7/10ths of the way down, then it'll go like a rat up a drainpipe.
Post #248450 2nd Jul 2013 7:43pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Yeah the Hawkeye dose say its the wrong way round, nothing to worry about.
Pete.
Post #248452 2nd Jul 2013 7:48pm
sc70
ok cheers, so the ecu thinks its the correct way? Thumbs Up www.Equi-Trek-Tregaron.co.uk
Post #248454 2nd Jul 2013 7:55pm
"Normally open", as in, the contacts of the switch are open and not touching, is "high" range.
when you select low range, the switch presses and the contacts close.
I don't know why these readers all sense them back to front (I think the later generation of nanocom sorted this problem out) i'm sure BAS or IRB can explain.
So, if you don't like the low range throttle response, just unplug the switch off the front of the transfer box (and put some tape over the plug to keep the poo out)
Post #248467 2nd Jul 2013 8:31pm
jst
i am surprised your not running two maps Si one on each switch setting! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #248487 2nd Jul 2013 9:06pm
sc70
no map yet James this is another 110 for a bit of fun Thumbs Up www.Equi-Trek-Tregaron.co.uk
Post #248497 2nd Jul 2013 9:15pm
davew
I was told (no idea if it's right or not) that all the original aftermarket boxes were cloned from one that was reverse engineered from a Land Rover test book. The original reverse engineered version had it the wrong way around (and also the clutch switch IIRC) so all the clones had the same problem.
Some of the clones were later fixed by their suppliers but most weren't, hence the Nanocom et al still read it backwards. http://www.yorkshireoffroadclub.net/
Post #248509 2nd Jul 2013 9:29pm
jst
overlanding then??? Thumbs Up Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #248512 2nd Jul 2013 9:33pm
sc70
thats the plan, 3 door and have put a cage on Thumbs Up www.Equi-Trek-Tregaron.co.uk
Post #248533 2nd Jul 2013 9:51pm
