Home > For Sale & Wanted > Seat rail extensions |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3467 |
Who are they made by? 1951 80" S1 2.0
1995 110 300TDI 1995 90 300TDI |
2nd Jul 2013 9:55am |
Culminator Member Since: 30 Apr 2013 Location: West sussex Posts: 305 |
Not sure but look like either Britpart or Terrafirma ones.
2nd Jul 2013 10:12am |
Mine are Mud, but a seatrail extension's a seatrail extension they all look the same and have the same functionality..... If you go through life with your head in the sand....all people will see is an ar5e!!
2nd Jul 2013 10:24am |
Exactly
2nd Jul 2013 10:28am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
Unless they're made by britpart.... then they'll probably bend
or not fit or break or leak... |
2nd Jul 2013 11:12am |
Perfect compliment for a Defender then! 'Warts 'n' all!' If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
2nd Jul 2013 12:15pm |
FFS can the trolls sod off!
they do fit, they're not bent and they are in perfect condition. |
2nd Jul 2013 7:02pm |
Oooh sense of humour failure
2nd Jul 2013 7:10pm |
shaun.mobile Member Since: 12 Dec 2011 Location: England Posts: 156 |
Anyone considered modifying the bulkhead removal bar to enable more seat travel without affecting the seat height?
I quite like the driving position but since driving a Flander I keep checking to make sure I am as far back as possible. I wouldn't mind an extra 50mm but don't want to be sat any higher and having to bob down to look out of the side windows. |
2nd Jul 2013 8:03pm |
