Home > Maintenance & Modifications > Interior lighting
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Interior lighting
Has anyone put an interior light to the middle row seating area on a 110. Is it just a case of piggy backing power from the front light?
Post #247755 30th Jun 2013 12:53pm
If you used LED bulbs you could piggy back it as the draw would still be lower than the incandescent bulb as standard. If you used standard bulbs you'd have to give it a dedicated power supply. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_
Post #247756 30th Jun 2013 12:55pm
ginjez
Thanks Steve, with mine being a DC I'm wondering if the loom would be tucked away in the head lining to power the rear cargo area light on a 110 sw Idea
Post #247760 30th Jun 2013 1:03pm
There is only one way to find that out really. Confused Either way what ever you do the head lining will have to come out or have some careful cable threading to do. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #247764 30th Jun 2013 1:21pm
Innuendomaster
There's nothing else behind the headlining in my MY10 DC, just the supply for the front lining light.
Post #247768 30th Jun 2013 1:40pm
In that case I would piggyback it from the front but make sure you use LED bulbs in there to prevent possible overload. Thumbs Up
Perhaps in the rear use just a LED light not the LR unit and that can be switched via the front light. Otherwise you will have it double switched. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
Post #247771 30th Jun 2013 1:42pm
landybehr
I can transmit the info, someone posted on a local forum only a while ago.
He says the wires that run from between the two standard lights are routed very much in a direct line.
If you carefully cut a hole into the headlining chances are high that it is possible to catch the wires and connect a third light to them.
I managed to find some nice LED lights. IIRC they need to be 39mm length to easily fit and hold properly tight. Real plug´n´play. They even fade out like with the original (though they flicker a little then, but not that it hurts Smile ). I think it´s not bad there is less current flowing - and less heat.
Look like this one:
http://bilder2.eazyauction.de/everybady16/...096_eA.jpg
Most of them a very "white" white. Sometimes it´s called xenon-white. I prefer a "warmer", more yellow white, just like the original bulbs. I had to search a while to find them on ebay.
Post #247880 30th Jun 2013 9:53pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
I took power from the rear light but made the lights either side locally switchable. They don't come on when the door opens, but can be used as reading lights or for the kids to look for stuff in the second row.
Post #247885 30th Jun 2013 9:59pm
JWL
Yep I've done it, I got another LR interior light assembly to match the other 2, cut a hole out in the headlining, found the three wires running to the rear light and just joined the new light in. It works exactly the same as the others and when I put leds in, 6led ones in the front 2 and a pad of IIRC 48 in the back, it can allmost be too bright inside and I'll often switch the front one by the interior mirror off. Why oh why they don't come standard like this I will never know Rolling Eyes
Post #247887 30th Jun 2013 10:00pm
