Home > Maintenance & Modifications > Cheap & Quick alternative to powering my Engel?
Page 1 of 3 123>
Innuendomaster
I've decided I'm taking the Sankey away next weekend, and although its got a Waeco aboard powered by battery's and solar panels I want to take my Engel too and keep that in the Defender. Time is short, so which is the best way to power it without mega ££££'s on a split charge.....and quick given the timescale
Post #245633 22nd Jun 2013 5:56pm
appaloosadude
United Kingdom 2003 Defender 110 Td5 DCPU Havana
You've pretty much got it sorted. Why do you need to charge it on top of what you've got? Whack a couple of ice packs in it if you've room? Or take a generator, should you have one.
Post #245638 22nd Jun 2013 6:25pm
Innuendomaster
So paying £600 for an Engel and I could have got a Ice box Laughing .
Post #245641 22nd Jun 2013 6:29pm
Lou Sparts
I,ve run a cool box off of a battery boost pack purchased from machine mart for about £55.Will charge through the ciggy lighter during the day whilst driving and run your Engel all night. 2005 Td5 90 XS
Steve
Post #245642 22nd Jun 2013 6:31pm
depends where you are going, if it's a camp site get a hook-up, otherwise consider a small petrol generator
Post #245644 22nd Jun 2013 6:40pm
Innuendomaster
I plan to be properly self sufficient. Next month I'm off to RIAT where we camp in a Armers Field along the runway. No hook ups there.
Post #245645 22nd Jun 2013 6:44pm
What year is your Defender? If it's MY12 or older then there will be permanent live wires behind the cover for the rear RH light cluster. Install a cigarette socket using those wires and plug your fridge in there. Eventually, it would drain your battery but as a quick and dirty solution it would be fine for a couple of nights. I powered my 60l Engle in exactly this way last weekend whilst camping at Dunsfold. Darren
Post #245705 22nd Jun 2013 8:07pm
Innuendomaster
2010 I'm afraid, 2.4
Post #245717 22nd Jun 2013 8:24pm
ARC99
The feed is in my 2008 110, it can be reached by either removing the rear off side speaker and reaching in or by removing the whole plastic fitting.
One purple cable and one black cable with clear/white plastic fitting that takes normal spade sittings. Don't make old people mad.
Richard
Post #245721 22nd Jun 2013 8:35pm
2010 is older than 2012 so you should be fine Thumbs Up Darren
Post #245730 22nd Jun 2013 8:48pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Then you are in luck Innuendomaster. Offside, rear behind speaker, black and purple wires, permenant live and earth that is fused at 20amps. Thumbs Up LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #245734 22nd Jun 2013 8:51pm
Do you know which fuse its linked to?
Post #245791 23rd Jun 2013 7:26am
Innuendomaster
Mines a Double Cab pick up, where would I find these wires?
Post #245811 23rd Jun 2013 8:37am
DiscoStu
United Kingdom 2013 Defender 110 Puma 2.2 SW Santorini Black
Gone on MY13 though? Sad My Disco 'best bits'
Defender 110 XS CSW 2013
Post #245821 23rd Jun 2013 9:22am
Stu plenty of other ways Thumbs Up
Post #245824 23rd Jun 2013 9:32am
Page 1 of 3 123>
