Home > Puma (Tdci) > Hot idle oil pressure
Naks
Gents,
I hope I'm being paranoid...
Hot idle pressure in my Puma has always been 1.6, since new, no matter which map is running. Since a week or so, this has been 2.0, so I've been checking things, but all is normal - oil level is fine, looks ok, no leaks, etc.
Oil pressure when driving 100kmh @ 2000rpm on a flat road in 6th gear is between 5.5 and 6.0.
Landy is going in for an oil change in the next week, but should I be worried? Could this be related to the cold weather and fact that coolant temp is not reaching above 86C unlike the usual 91C?
Thanks! --
Post #245148 20th Jun 2013 5:57pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Cold weather Rolling with laughter what like 17 / 20c. But seriously if the coolant isn't getting hot then the oil won't be so it'll be thicker hence the higher oil pressure.
Post #245155 20th Jun 2013 6:03pm
Naks
Cold weather - it's getting down to 9C these days Big Cry
What you say makes sense, but why would the coolant not get beyond 86C, nothing has changed on the landy... --
Post #245158 20th Jun 2013 6:12pm
yobbie
It was about 29c when I was in Gordon's bay Thumbs Up Are you driving enough distance to get to full temp?
Post #245199 20th Jun 2013 8:46pm
Naks
I drive 25km to work. After 10km, at the last traffic lights of the town driving part of my journey, the coolant temp is usually at 90C. I take this as and indication that the engine is at operating temp and I gun it up a long hill. The rest of the trip is open road at 100kmh.
Nowadays, even when I get to work the coolant temp is only at 85-86C... --
Post #245253 21st Jun 2013 6:42am
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
Hey...!!!! Watch-it!
20degC is freakin cold for us! Embarassed
Post #245367 21st Jun 2013 1:56pm
yobbie
Sounds like the thermostat is not working properly. Long hill Sir Lowr s pass??
Post #246022 23rd Jun 2013 7:54pm
Naks
Hmm, could be, will ask the mechanic to check it out as well.
No, R44 by Lord Charles in Somerset West. Not that long, but a nice race uphill none the less. --
Post #246077 23rd Jun 2013 9:02pm
yobbie
Just spoken to my mate in Cape Town (just off on a full moon bike ride in the city) next time we're there hopefully will be doing some off roading Thumbs Up
Post #246103 23rd Jun 2013 9:26pm
Naks
Hi all,
After an oil change, all appears to be back to normal: the hot idle oil pressure is now at around 1.7-1.8, but jumps around a lot, leading both the indie and myself to conclude that the earth on the Madman unit is probably loose.
Coolant temperature is back to normal at 91-93C and there has been no more coolant loss after replacing the cap (no streaks on the bottle either).
I have now switched from the stealer-mandated Castrol Magnatec Professional A5 to the Fuchs Titan Supersyn F (http://www.opieoils.co.uk/p-68918-fuchs-titan-supersyn-f-5w-30-engine-oil-ford-wss-m2c913-c-913c-acea-a5b5.aspx).
After the first drive, the engine sounds a lot smoother, and feels a tad livelier. Schalk recommends another oil change in 2500km. Considering 8L of the Fuchs cost R536, this is not bad at all. --
Post #247859 30th Jun 2013 8:10pm
Naks
The high oil pressure readings are back Confused
Sometimes before even starting the landy, the unit displays 1.1bar. So I cannot trust it any more, getting it seen to asap.
Anyone else keeping readings of their oil pressures? --
Post #252155 18th Jul 2013 1:43pm
Naks
Guys, I just came back from the installer.
We removed the sender, re-crimped everything, checked the earth and then ran another earth directly to the sender itself.
This did not solve the issue, still getting weird readings.
We phoned LandyOnline, and they said while it's unlikely that a 2-month old send would fail again, we should check the connection harness and the actual connections on the back of the EMS unit.
So I'm going to have to take it back to the installer once they get a new harness and sender, just in case either or both needs replacing. --
Post #253436 24th Jul 2013 11:48am
