Home > Td5 > Banging from drivers side rear
johnnyd
Hi all
Ever since buying the landy, there has been a banging/knocking coming from inside I think when you go over bumps, I really want to find out what it is, I have removed the jack from behind the seats just now, it's not that, the rear is empty, I really can't work it out, does the spare wheel on the back door rattle, I have shaken it when stationary, and it doesn't seem to make a similar noise......anyone any ideas? It's definitely rear drivers side I think
JD 2008 TDCi 2.4 XS CSW
Post #244084 16th Jun 2013 3:27pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
just try moving rear door up/down when its open, hinges could have had it if you have spare wheel on door..Or its not adjusted properly when shut.... Putting Dreams on Drives at JLR Solihull..
Post #244087 16th Jun 2013 3:40pm
ickle
shock mounts, trailing arm rubbers, bonnet hinge rubbers even???
Keith
Post #244094 16th Jun 2013 4:16pm
johnnyd
Found it.......took the spare wheel off eventually, needed a hammer on the wheel spanner, and the fixing it was on ( a black tubular locking bracket system) made a similar noise, took it for a spin and no rattle, so the weight of the spare wheel is making the bracket bang over bumps, is there a fix as it is quite annoying?
Post #244096 16th Jun 2013 4:20pm
ickle
If its a Mantec design, cut some thin plastic discs and insert in the pivot points, then nip the pivot bolts up.
Thumbs Up
Post #244100 16th Jun 2013 4:36pm
johnnyd
Its that style but not mantec or bearmach, here is mine
https://www.dropbox.com/s/waxy779v6jr9ytc/photo%20copy%202.JPG
Edit....I think this is mine....
http://compare.ebay.co.uk/like/28111154742...mp;ff14=66
Post #244111 16th Jun 2013 5:26pm
