Home > Td5 > TD5 Clutch dual mass flywheel
Page 2 of 2 <12
barbel jim
Has anyone used a floor transmission jack to drop the gearbox ? My spigot bush is dying ! Draper do a 150 kg for £85 so considering it ?
Post #427331 30th May 2015 10:44pm
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Hi Jim, I used a sealy transmission adaptor that fits to a trolley jack, worked a treat. The transmission jack, if it's the one I'm thinking of you may struggle for clearance, as you will need to move it out of the way so that you can access to the clutch, just a thought.
Post #427377 31st May 2015 8:05am
barbel jim
My thoughts with this route is no need to take out the floor panels Whistle Ive seen the trolly jack adapters, any good ??
Post #427392 31st May 2015 9:01am
tazmarkuk
Trolley jack adapter very good, however i did split the boxes to make life easier and only removed the transmission tunnel and the panel under the cubby box
Post #427462 31st May 2015 11:41am
Page 2 of 2 <12
