Home > Td5 > Exhaust manifold options
adseybear
Canada
So since the remap I've got the dreaded screech under load that indicates i've warped/blown exhaust manifold gasket.
What are my options? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #242832 11th Jun 2013 7:40pm
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
we have some skimmed ones on the shelf, fit that with our stud kit......... Putting Dreams on Drives at JLR Solihull..
Post #242846 11th Jun 2013 8:23pm
adseybear
Canada
Can you give me an idea on prices?
And am i going to have trouble extracting snapped studs? 2003 Defender 90 Td5 CSW Belize Green - "Betty"
Post #242852 11th Jun 2013 8:38pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
I skimmed mine & changed the studs for Wurth ones. The studs were about £16. One was broken but not too bad to extract.
Post #242859 11th Jun 2013 9:24pm
adafish
not unless you take care...drop me email.... ada@irbdevelopments.com sort something out for you... Putting Dreams on Drives at JLR Solihull..
Post #242860 11th Jun 2013 9:25pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
As Ada says you want one which is skimmed the ribs removed and bigger bolts job done Thumbs Up
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #242867 11th Jun 2013 9:51pm
Allisport do a nice new cast one, without the EGR hole on the end. don't know about price though.
Post #242904 12th Jun 2013 5:21am
barbel jim
JE engineering (Coventry)will supply the stud kit- and will swap the manifold for a skimmed one about £400fitted IIRC. Or just get the stud kit, change yourself (probably have to dill and tap a stud or 2) and get a local engineer to skim your existing manifold about £50 Whistle Thumbs Up
Post #242905 12th Jun 2013 5:32am
yobbie
It is nice Jim but when I enquired it was £800!!!
Post #242908 12th Jun 2013 6:34am
Porny
Site Sponsor
Steve
I disagree..... from some test work I did on a customers vehicle, removing the webbing made no difference, and 10mm studs might solve the problem for a bit, but not needed. Also, making the very back stud 10mm means you get very close to the water jacket... which if you break into scraps the head.
A skimmed manifold with a few tweaks and a stud kit with spacers to help heat dissipation - the manifold will be problem free.... unless your running stupid mapping.
Also, if needed I have a proper jig I will rent out to allow you to centre holes properly.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #242973 12th Jun 2013 2:58pm
adafish
oi you ^^^^^^ did you get my email about Friday ?.......bring me something back nice too.... Wink Putting Dreams on Drives at JLR Solihull..
Post #242981 12th Jun 2013 3:48pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
I have one of Ian's skimmed manifolds with an uprated stud kit and it's been perfect now for 3 years despite the heavy work I make it do. www.td5.org
Post #243102 12th Jun 2013 10:40pm
johnnyd
Am I likely to get this screaching issue with a stage one remap .
JD 2008 TDCi 2.4 XS CSW
Post #243127 13th Jun 2013 6:46am
Not sure about likely, but certainly possible. It depends on how it's driven and used. My 110 was remapped about 5-6k miles ago and is fine so far but my wifes old DII only failed in this way after about 30k miles so it's difficult to say. Darren
Post #243128 13th Jun 2013 6:57am
johnnyd
Hmm thats a bit worrying, do'nt want to have to spend another 500 Quid + after 300 for a remap......any other possible side effects of a stage 1 ?
Post #243139 13th Jun 2013 7:56am
