Home > Puma (Tdci) > Heating Oil
shaun.mobile
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Fuji White
Heating Oil
I have an empty property where I am in the process of converting from oil to gas.
has any body tried / or knows the effect of running heating oil as a diesel additive.
I probably have 300 litres to get rid of.
Post #241563 6th Jun 2013 9:41pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
I'm pretty sure that's illegal, but my 'old neighbour' found it worked nicely in his diesel van Whistle
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #241571 6th Jun 2013 9:47pm
Lou Sparts
Do not run this in your Puma it will wreck the high pressure pump as it does not have enough lubricity to lube the pump.
Apart from being illegal as no fuel duty has been on it,it,s just not suitable for modern diesel engines.
I beleive kerosene was used to do the development work on the Td5 injection system but only because it accelarated the wear and shortened the test time required.
I,m sure one of the neighbours would buy it off you. 2005 Td5 90 XS
Steve
Post #241585 6th Jun 2013 10:12pm
Quite apart from the risk to your engine, the financial consequences of doing this are too great to risk. HM Revenue & Customs are very proactive in clamping down on the use of untaxed fuel, and have very draconian powers of entry, search, and seizure (far more than the police). It really isn't worth the risk.
It will probably be fine in an older diesel engine only used off-road, such as a genny or old tractor.
Post #241591 6th Jun 2013 10:27pm
Lou Sparts
If you were to use it off road in some sort of plant it would be a good idea to add some engine oil to it to increase its lubricity.
Heating oil is known as 28 second oil and diesel is known as 35 second oil as this is the amount of time it takes to run through a viscosity cup.Adding engine oil to heating oil will bring up the viscosity and therefore its lubricating properties.As said previously probably alright for an old tractor or similar. 2005 Td5 90 XS
Steve
Post #241596 6th Jun 2013 10:39pm
ericvv
If customs would check you on the road here and find the slightest trace of untaxed fuel as used in farming equipment, they would simply calculate your theoretical total fuel consumption over the entire life of the car basis the odometer figures and basis LR official Defender fuel consumption figures, calculate the amount of tax on 100% of all those liters you supposedly have used since new, multiply that amount X2 as a fine, and send you the bill for that amount plus some more for their expenses...... Running untaxed farmer fuel is risky business I would say. You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #241615 7th Jun 2013 5:08am
AndyS
I'm pretty sure it's legal if you pay the tax, HMRC don't mind you making your own (from chip fat for example) as long as you pay the tax.
http://customs.hmrc.gov.uk/channelsPortalW...e=document
However, the above page says:
Quote:
4.2.1 Exempt producers/users
If you have produced or used less than 2,500 litres of:
any biofuel, or
any other fuel substitute or additive
within the last 12 months, and/or expect to produce or use less than 2,500 litres in the next 12 months, you are an exempt producer and do not need to register with us and account for duty.
Post #241617 7th Jun 2013 5:44am
NoDo$h
But this isn't a fuel substitute or additive., it's a refined fuel produced and sold under a different taxation class.
No is the simple answer. You can debate the pros and cons and put forward wierd and wonderful schemes all you like all you like, but the answer is still no. Otherwise people would declare tax on a couple of hundred litres of red (agricultural) or white (heating kerosene) at the start of the year, then run on it all year long with a copy of their "declaration" in their back pocket.
If anyone thinks they have a clever scheme that beats this, be assured HMRC have seen it all before and will nail your arse to a door Thumbs Up
54 Freelander modded for mud
2008 D3 SE
2010 90 XS SW
1978 88 Series 3 undergoing surgery with a new owner
2007 90 County Truck Cab - gone
2006 D3 SE - gone
2004 Freelander Sport - gay
1999 Disco V8 ES rotted to bits
Post #241622 7th Jun 2013 7:35am
camelman
I agree that it's not even worth considering, particularly as HMRC can nab your vehicle if you're caught with it!
http://customs.hmrc.gov.uk/channelsPortalW...4#P36_1845
5. The law
5.1 Offences and penalties
Offences
You may be liable to -
civil penalties under Section 9 of the Finance Act 1994 or an Excise wrongdoing penalty under Schedule 41 of Finance Act 2008.
your vehicle (or engine) being seized and forfeited.
if your conduct involves dishonesty, a penalty of up to 100% of the duty evaded may be imposed.
If you:
misuse or supply oil (other than fully duty paid fuel) for use as fuel in a road vehicle
misuse or supply rebated kerosene for use to propel an excepted vehicle or as fuel in an engine (other than to provide heating) or
mix any rebated or duty free oil with any oil on which no rebate has been allowed.
Post #241630 7th Jun 2013 8:24am
Caterham
so ignoring the tax implications as presumably you could register and pay the fuel duty?
what are the known mechanical implications and is there an accurate means of additives available to remedy and possible issues?
Post #435246 2nd Jul 2015 9:37am
munch90
Simple answer
dont bother
sell it to someone with oil heating
Post #435260 2nd Jul 2015 10:38am
Caterham
hmmm
you know me better than that.........whats the complicated answer tho ?
only joking Rolling with laughter
Post #435262 2nd Jul 2015 10:51am
munch90
by the time you muck about getting it out of tank into two 45 gallon drums , transport it , put it in another tank , you need to leave it standing for a week after moving it to let the crap settle , lose a set of clothes because you will end up with it all over them
be honest your be lucky to give it away!
been there done it !
Post #435269 2nd Jul 2015 11:01am
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Buy an oil fired workshop heater and burn it yourself or find a friend with a suitable waste oil burner.
As Munch said above the bottom of the tank will be full of sludge and debris which will cause all sorts of problems if it gets into a boiler. 2014 110 2.2TDCi XS Station wagon - GONE
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - GONE
2024 110 D250 X-Dynamic HSE
Post #435295 2nd Jul 2015 1:05pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
The original post is referring to the use of kerosene as a diesel additive. Additives are added in very small amounts. It's a totally different scenario to running your engine on it. I don't know of its values as an additive, but I think I'm right in saying that it burns hotter than diesel. 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #435369 2nd Jul 2015 7:00pm
