Home > Maintenance & Modifications > What's the best oil and how much
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Right as most of you know abt my gearbox I want to know the exact amount you should have in your defender gearbox ad also what oil should I use genuine ford gearbox oil genuine Landrover oil or is there something better ??
Kind regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #240789 3rd Jun 2013 6:23pm
excossack
I would speak to Opie oils and see what's suggested. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #240794 3rd Jun 2013 6:42pm
Jimb1978
England 2002 Defender 110 Td5 Black LE Java Black
I put Fuchs Titan sintofluid sae 75w 80 in my r380. It made a big difference as it was crunching a lot between 1st and 2nd. This problem was solved by changing the oil and the whole box was smoother. I don't know how old the old oil was though so standard land rover stuff may well have done the trick.
Post #240807 3rd Jun 2013 7:26pm
Jimb1978
Forgot to say, I bought is from opie oils Thumbs Up
Post #240808 3rd Jun 2013 7:26pm
spudfan
Ireland
I used this in my Puma 2.4
http://www.micksgarage.com/proddetails.asp...p;pk=EA876
Main gearbox 2.2 litres at service oil change or 2.4 litres dry fill at factory.
Transferbox 1.6 litres.
http://total-gbr.lubricantadvisor.com/advi...2f5afe4d02 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #240810 3rd Jun 2013 7:27pm
big steve
Hmm if always filled to bung in transfer box and I use LSD combine oil in there
Gearbox it just been rebuilt so should it be 2.4 ?
Steve 2015 2.2 tdci hardtop xs
Post #240815 3rd Jun 2013 7:38pm
spudfan
Ireland
If the gearbox is empty then 2.4 litres. Seems filling to the bung is not recommended on the gearbox on the Puma as one does on older Land Rover gearboxes. Seems it (filling until it runs out the bung) can lead to overheating on the Pumas. Might be something to do with the slight angle the gearbox sits at. 1982 88" 2.25 diesel
Post #240820 3rd Jun 2013 7:47pm
big steve
Yes only do hat on the transfer box anyway cheers spud fun 2015 2.2 tdci hardtop xs
Post #240822 3rd Jun 2013 7:48pm
