Home > Maintenance & Modifications > ABS Wheel Sensor Gap?
K9F
From the workshop manual.......
Check ................wheel speed sensor for correct air gap.
Anyone know what this should be? Can't find it anywhere...... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #240446 2nd Jun 2013 1:14pm
Doesn't mention the depth at all in RAVE either, just says "carefully re-insert the ABS sensor"
Is there a "stop" where it won't go in any further? (or is said stop, the bell of the CV?)
Maybe as far as it'll go then back up 1 or 2mm? Question Question
Post #240451 2nd Jun 2013 1:47pm
K9F
Eureka!!!!!
Thanks for the reply. Bow down
Answer was staring me in the face all along and I was trying to look too deeply.
The gap should be as small as possible. I've spent all day fart arsing about with the sensors when I should have just tapped them all the way home. I made it difficult by not wanting to remove the wheels, jack it and remove the inner rear dust covers. I also didn't wish to potentially damage the sensors by fitting them all the way home and them catching on the rotating part of the disk.
There is another thread but all my woes started when braking heavily the other day and thereafter my TC coming on periodically at low speeds and gradually getting worse. Had to pull the 30 amp fuse in the end.
I stuck it on the tail end of my old thread from three and a half years ago as it was related....
http://www.defender2.net/forum/topic2394-30.html
Chafed cable it was.....no fault codes as it wasn't seeing an issue. Found it! Fixed it! Am now an extremely happy, chuffed chappy! If not a bit waxoyled up. T-shirt needs the bin I think! Thank you.
Chafed 2" cut out from end of connector portion. You can clearly see the conductors that were shorting to earth through the chassis.
Post #240452 2nd Jun 2013 1:58pm
Happy days, all sorted Thumbs Up
Post #240464 2nd Jun 2013 2:47pm
