Home > Td5 > Speedo calibration
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Speedo calibration
OK, I've changed the transfer box this week from my 90 Td5 (1.4 gearing) for a Discovery one (1.2 gearing), works very well, very pleased with the results, only thing is the speedo is reading about 10% too slow compared to a GPS trial. When doing 55 on the GPS the speedo's reading 50 and so on.
I'm running 235/85/16's at the moment.
I put the green transducer from the Defender box onto the Disco transfer box, is there a way of recalibrating it?
Is it a case of swapping the speedo drive to a different one?
Also, will it give me low mileage in the long run?!!
Post #238583 25th May 2013 9:00pm
My 110 and 90 also does the same thing.
If i fit my 255/85's, then the speedo is spot on with the GPS
Post #238585 25th May 2013 9:11pm
dorstsmith2
United Kingdom 2003 Defender 90 Td5 HT Caledonian Blue
Speed calibration
This may help
Land Rover 90/110 speedo drive gears
• Colour: blue/20 teeth - Part number: FRC3310 - Tyres: 7.50/16 or 235/85/16
• Colour: green/21 teeth - Part number: FRC3311
• Colour: yellow/22 teeth - Part number: FRC3312 - Tyres: 205/16 tyres
• Colour: red/24 teeth - Part number: FRC3313
Thumbs Up
Post #238586 25th May 2013 9:14pm
VeeTee
Netherlands
You can change the speedo drive for one with more or less teeth, calculate the correct ratio / number of teeth according to your measurements.
frc3310 blue ------- 20 teeth -- 7.50,235/85 or 255/85 tyres 20D & 22D transfer box
frc3311 green ------ 21 -- all 90 vehicles excepth the 50th ann edition.
frc3312 yellow ----- 22 -- 90 with 205 x 16 tyres
frc3313 red -------- 24 -- 32D transfer box
Discovery 1 [200Tdi/V8]
frc3310 blue ------- 20 -- diesel
frc9339 ------------ 23 -- [see note]
frc3310 blue ------- 20 -- V8 efi
frc9339 ------------ 23 -- V8 twin carb
Note frc9339 diesel for gulf states vehicles,no colour code listed, auto trans Tdi vehicles
Edit: @dorstsmith2: I have to learn to type faster! Laughing Cheers, Vincent
MySite
Post #238588 25th May 2013 9:21pm
dorstsmith2
Speed calibration
snap Thumbs Up in hare and tortoise, tortoise always wins Whistle Rolling with laughter
Post #238590 25th May 2013 9:23pm
Lambley
Thanks for the replies, I guess I'll have to remove/look at the one on the car at the moment and work out which one I'll need, will the one from the original 90 Def box fit and read ok or will the gearing make it read wrong? Sorry if that doesn't make sense.
Post #238618 25th May 2013 11:30pm
davew
If your original transfer box read correctly then just use the speedo drive gear from that one. The speedo drive is on the output of the transfer box so the ratio of the transfer box has no effect on the speedo. http://www.yorkshireoffroadclub.net/
Post #238620 25th May 2013 11:43pm
Lambley
Ok, thanks davew, that makes sense, cheers for the reply. Thumbs Up
Post #238621 25th May 2013 11:47pm
VeeTee
Netherlands
What colour speedo drive is fitted now? Cheers, Vincent
MySite
Post #238622 25th May 2013 11:51pm
Lambley
Not sure, I've not taken it out to look at it to be honest, I just swapped the sensors over, black to green.
Post #238623 25th May 2013 11:53pm
VeeTee
Netherlands
Think it will be OK iff you put in the original speedo drive from the Disco transfer box. Cheers, Vincent
MySite
Post #238626 26th May 2013 12:04am
Lambley
You mean the one out of the defender box?!!
Post #238627 26th May 2013 12:07am
VeeTee
Netherlands
Sorry, yes the original from the Defender tbox. Cheers, Vincent
MySite
Post #238630 26th May 2013 12:25am
Lambley
thanks VeeTee, I'll do it tomorrow. Thumbs Up
So, does that mean that my mileometer is out too at the moment? If so, I'm getting 10% better fuel economy than I thought?
Post #238631 26th May 2013 12:45am
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I think in most cars you will find the GPS is 5mph in front of your clocks most car company give as much as 10% on clocks
My yaris reads 70?but GPS reads 64-65
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #238662 26th May 2013 11:26am
