![]() | Home > Off Topic > Ground anchors |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
What anchor are you using and why,
Why are ground anchors so expensive compared to boat anchors. Why can't i use a boat anchor instead. i.e. a bruce or danforth. I read about a chap who use's the folding grapple type, if it doesn't grip he just piggy backs another one behind it and so on. Original Member Pie n Pea Club. 110 HCPU Tipper |
Mad Cow Member Since: 27 Oct 2009 Location: Hertfordshire Posts: 292 ![]() ![]() ![]() |
Very nice!
Where did you get it from? MAD COW 2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport Project90 |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Best one i have found is the X-Eng one http://www.x-eng.co.uk/X-Anchor.asp very light and easy
That.. or a Devon4x4 one, both popular on challenge events But both give storage issues though,, Have used one of the ones in Andrew's picture,, but can not remember the name,, start with a P, IIRC ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8360 ![]() ![]() ![]() |
i use an X-Eng one, its a good bit of kit and excellent being light to chuck about on events etc. if storage is a problem then consider the devon one, or plate and pin if time is not of an issue. if i wasnt doing challenges where speed is of the essence i would go plate and pin and the Rec Mechs will have some kicking about!! Cheers
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 ![]() ![]() ![]() |
PRT ![]() Portable Rescue Tree ![]() |
So a PRT and a set of pins n plate and I'll be reasonably covered for the average greenlane and shouldn't have to resort to burying the spare wheel
![]() ![]() 110 HCPU Tipper |
PRT,, yep that the jobby http://www.anchorright.com.au/products/ground-anchor-prt California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
