![]() | Home > Maintenance & Modifications > About to swap transfer box... speedo drive advice please?!! |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
Keep the one that was in your 1.4, as the speedo drive is relavent for whatever tyre size you have.
the 1.2 from a disco would have (assuming he box came from a standard unmodified vehicle) a speedo drive for smaller tyres. Remove the electronic transducer (which is also different between the disco and defender type) and the whole metal tube thing should (with a bit of levering) slide out, you can then change the drive gear and re-insert the unit with some copperslip on it. |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 ![]() ![]() ![]() |
Cheers Jim, just a quick and maybe daft question then...
What do I need to remove to get at the transfer box to make it easier - exhaust? tunnel? cross member? props? All of them?!! |
Christian Member Since: 23 Feb 2013 Location: Doha Posts: 66 ![]() ![]() ![]() |
The workshop manual mentions the intermediate pipe and muffer for the exhaust, and you'll have to suspend the driveshafts as nothing will hold them anymore ![]() Removal and Installation on a Puma The only tricky thing is not having the special lift, as the case is about 60kg... Good luck ![]() |
