Home > Off Topic > Topix access
bvandyk
Topix access
Hi
Does anyone have access to Topix?
I would like to get the details of the following two bulletins. (It's for a Freelander 2. Not Defender)
LTB00342v2 and SSM46477
Both related to rear diff.
Thanks
Post #233347 7th May 2013 10:07am
Naks
SSM46477
From http://www.freel2.com/forum/post131178.html:
Reference: SSM46477
Date: 25-Nov-2010
Issue: Excessive rumble/humming noise or high pitched whine coming form the rear of the vehicle
Cause: Root cause, Pinion Tail Bearing spalling caused by subsurface material deformation. Cause of subsurface deformation is static overload.
Action: For reported concerns where LTB00342 (Rear Differential Lower Level Repair) has been carried out or if a Rear differential is replaced, please be aware that a software update has been made available to help prevent premature pinion bearing failure in the future. This update should only be applied to the Haldex Coupling control module if the lower level pinion bearing repair has been carried out or if the rear differential assembly has been replaced.
Note ! This software is only available for Generation 4 Haldex couplings which were fitted from Start of 2009 MY vehicle manufacture. A number of Vehicles built before 2009MY originally fitted with a Generation 3 coupling, may have since been fitted with a Generation 4 coupling during service repair and could also have this software update applied if required.
LTB00342v2
And http://www.freel2.com/gallery/albums/userpics/11383/LTB00342.pdf --
Post #233409 7th May 2013 1:44pm
bvandyk
Thank you very much!!
Post #233414 7th May 2013 1:56pm
