Home > Technical > Clunking between gears and a rumble/vibration
excossack
Yesterday on the way to a rally, I picked up a clunk between gears and also at times what sounded like a stone caught in the brake discs.
Onwards to Kielder forest for the Pirrelli Rally.
Once moving the car felt OK when I got to about 45mph I can feel a vibration through the steering wheel. It was like driving of a rumble strip but not as harsh.
I suspect this is wheel balancing?
On the motorway, the car still had the rumble feel, certain speeds felt smoother than others, I think the sweet spot was around 58-60mph. Also going to check the wheel nuts.
Coming back down the gears on the A roads I got a clunk between the gears. I noticed that if I was a bit slower in the gear changing the clunk was reduced.
Checked the props and they felt OK for play, with the hand brake on I had a very slight movement in the rear prop and the front one felt OK as well. With the handbrake off there is some play in the front and rear diffs/transfercase, but not sure how much is too much.
I can liken it to something has stopped moving between gear changes and then starts again with a clunk.
Also discovered that I can get the same noise by backing off the go pedal and then back in it again quickly. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #232826 5th May 2013 1:02pm
excossack
I check the A frame ball joint and there was only slight play. The noise to me sounds more central G/box Transfer case area? Any thoughts? 1999 Defender TD5 110
Regards
John M0VAZ
Post #232995 5th May 2013 9:04pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Two thoughts - I had a double carden failure that went quckly from a trittering/squeeking noise - caused the front prop to lock against the gearbox. Secondly - take a look at my post about the big nut coming loose on the transfer box to front prop flange - u/js fine but the flange can be moved by hand side to side - just tighten the nut - vibration at pretty much all speeds
Post #233001 5th May 2013 9:15pm
v8steve
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Rimini Red
my first check would be prop uj's . 110 xs s/wagon
s3 swb soft top
Post #233002 5th May 2013 9:20pm
excossack
Big nut on the front T/C output OK.
With prop removed clunk still there.
Onto the rear and found this. Does this look knackered to you ?
A new to be ordered me thinks. 1999 Defender TD5 110
Regards
John M0VAZ
Post #233112 6th May 2013 2:44pm
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
Yep! That's proper f***ed Tommy! Replace the UJ, while you are at it replace the other end as well.
Post #233170 6th May 2013 6:17pm
excossack
The other end is sweet, IIRC it got replaced about 18months ago. 1999 Defender TD5 110
Regards
John M0VAZ
Post #233179 6th May 2013 6:43pm
Lucky you found it in time..... I had one come apart on my old lightweight (although that might have had something to do with the V8 under the bonnet and my size 11's Whistle Whistle Whistle
Post #233185 6th May 2013 6:51pm
excossack
I was lucky as I did 400 miles with it on Saturday! Will order a new one tomorrow and some other bits.
Now, I need to suss how to change it. 1999 Defender TD5 110
Regards
John M0VAZ
Post #233230 6th May 2013 8:13pm
pope10001
To be honest whilst it is out you may as well replace the other end as well, it's already had 18months abuse and they aren't a fortune to change. Personally I would do it for peace of mind.
Regards,
Mark
Post #233380 7th May 2013 11:51am
excossack
I've ordered two new UJs from DefenderBits so will do both for piece of mind. Just hope the internal part of the UJ isn't damaged 1999 Defender TD5 110
Regards
John M0VAZ
Post #233397 7th May 2013 1:06pm
pope10001
Internal part???
Post #233431 7th May 2013 2:53pm
excossack
The bit where the cups sit in the UJ (bit with circlip in) 1999 Defender TD5 110
Regards
John M0VAZ
Post #233433 7th May 2013 3:00pm
pope10001
They should be fine.
Post #233506 7th May 2013 5:26pm
excossack
New prop UJs arrived today, So far not had much joy extracting the old UJs, Removed the cir-clips one on bit of the UJ the other cir-clips have broken off and left bits behind. Maybe I need a hydraulic press....
Tried the socket method to extract the UJ but despite swinging on the vice they ain't moved!! 1999 Defender TD5 110
Regards
John M0VAZ
Post #233830 8th May 2013 5:52pm
