Home > Maintenance & Modifications > Recommendations for LED rear work lamp for camping etc...
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
I had the rear Land Rover work lamp on my 90 and found it be pretty rubbish. The new LED lights seem far better but more expensive. Any recommendations for a LED strip unit to fit above the rear door? I've looked at the Lasers that Brendan is selling but I image they're designed for throwing a narrower light beam further than I need.
Thanks.
Post #232787 5th May 2013 9:00am
K9F
Each to their own but for good quality and a good product this would be my 'weapon of choice.' Not a srtip but excellent value for money with great reviews. Thumbs Up
http://www.zenoverland.com/lighting/rigid_...ually.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232793 5th May 2013 9:15am
leeds
LED lights come with a wide variety of quality, prices and light output.
I agree with K9F about sticking to good quality!
The Lazer Lamp ST4 is a cracking unit gives out about 3,500 raw lumens 88% efficient and cost £240
The Rigid Industry Light I have not used but they have a good reputation. The one Mal links to as 2600 lumen output (raw or effective) and cost £255
However personally I would NOT recommend either unit as a work lamp on the back of a Defender!
WHY?
Work lights are mounted at about 1.7-1.9 m high which is just above eye level. Look at one of those lights and you will be 'blinded'. Great if you could get them 4-5m+ above ground level but not at eye level.
Other choices? Consider the Vision X light. Light output at 900 lumens, cost £90 with a 45 degree light pattern and draws less then 1 amp.
So consider carefully how you want to use the work lights. Need more light output/area covered? Use two one on either side and angled as required.
I personally would avoid the cheaper ones.
Brendan
Post #232800 5th May 2013 10:04am
K9F
Brendan
I can see where you're coming from (but not if I'd looked directly into the light) but others do recommend them for that very purpose.....price is also for a pair not a single unit. Thumbs Up
From the reviews....
Very quick delivery, the lights are great !
I have mounted them on CB aerial gutter mounts on the back of my land rover as worklights.They are awesome....
Not as a worklight but for front use....
I was looking for a light that gave me better visibility at a closer range than the halogen spots and headlights currently on my Defender....The light is self is clean, crisp and very well focused. I am very impressed by these lights and would recommend them to anyone. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232801 5th May 2013 10:09am
boode
England 2003 Defender 90 Td5 HT Rutland Red
As Brendan says the D2 Duallys will blind you - but you do get a pair for the £255 so would be very bright (5200 lumens).
The original Duallys at £150 a pair would be less bright but possibly still too bright unless you need serious light.(I have both on the front of my 90)
As a back light I have a round LED which gives a good light for general work / camping / reversing but will not blind you - also cheaper than the above
Sold by Devon for £65
http://www.devon4x4.com/index.php?page=sho...;Itemid=14
Post #232803 5th May 2013 10:21am
K9F
The Rigid Industries SR-Series 50" LED lightbar kicks out 16,000 raw lumens and will also blind you. It also should maybe state on the instructions "Induce vomiting if swallowed as it may choke you!' or 'Seek medical advice if you accidently sit on it and find yourself impaled upon it up your crimper'!
Sense and sensibility must prevail here, or buy a few candles and make sure you don't burn yourself when lighting them!
Whistle Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232805 5th May 2013 10:45am
leeds
Odin asked for recommendations on rear work lights.
People have vastly different requirements for rear work lights.
Are they for use as just extra reversing lights, or a camping light or to light up the bottom of a work trench etc?
Bottom of a work trench then max light output might be a major consideration
Camping light then less light output required but a lower current draw is of importance.
One of the other reason for suggesting a Vision X light is that it is a 10 watt light drawing less then 1 amp whereas the Rigid Industry light draws about 2.5 amps/unit or 5 amps for the pair
For a camping light current draw is a major consideration alongside light output.
Brendan
Post #232809 5th May 2013 11:11am
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I have 4 of the small Vision X on my Transporter for camp lights and must say they are great Thumbs Up they only draw 0.6 amps. I paid €40 each as I'm friends with the main European importer for them Whistle
Post #232811 5th May 2013 11:25am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Not a strip but I have an LED which Brendan supplied at the Trek Overland gathering which is great for camping (as long as you don't want to light up the whole campsite). Can't remember any details apart from they came in a number of versions from spot to flood - mine's a flood.
That's reminded me - must paint the garage door! Very Happy
[/img]
Post #232834 5th May 2013 1:49pm
K9F
Blimey, shouldn't have looked at that last photo......burnt me friggin' retinas it did! Cool If you go through life with your head in the sand....all people will see is an ar5e!!
Post #232912 5th May 2013 6:10pm
wyvern
...All posts to K9F to be in Brail from now on .... Cool Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #232923 5th May 2013 6:20pm
cobs
who wrote that I wonder? Confused
Post #233020 5th May 2013 10:17pm
Odin
Thanks, some good advice in there.
Post #233070 6th May 2013 8:33am
walfy
I went to Zen Overland 2 weeks ago. After a recommendation on here about some quad bits and pieces. The shop is just a counter and his stock isn't the most extensive but he more than makes up for that with enthusiasm and offering to get whatever you want.
I purchased a helmet and will be going back for some other bits and pieces. A pr of D2's for definite.
Plus Gabriel the owner is an all round top bloke, took time out to have a chat with me about my needs and then offered to see what was available on the market. Had a mail 2 days later with all the info 110 D250 SE HT
110 USW SOLD
Polaris RZR 900XP SOLD
Post #233095 6th May 2013 10:47am
WarPig
How do you all mount your rear work lights, im assuming the only way is to do it as cobs has by drilling a hole above the gutter?
Post #233131 6th May 2013 4:46pm
