![]() | Home > Maintenance & Modifications > Rusty hinge bolts.. |
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
I'm using these:
http://www.a2stainless.co.uk/Defender-90-S...AQHS8.aspx
But Brendan (4x4 Overlander) does nicer ones (for more £).... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
| StuLandy Member Since: 28 Jul 2012 Location: Here, there and Everywhere!! Posts: 43
Cheers Martin, they look spot on..
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584
The Nakatanenga VAST4DR kit contains all you need to do the doors on a 110 SW and is £59
OK a couple of quid more but the Nakatanenga sets are the only sets with GENUINE Land Rover heads on for the door bolts. For £99 there is the VAST110SW set. Yes a few quid more but contains about 430 stainless bits with the genuine door bolt heads as well. That is good value and is the most comprehensive set I am aware off especially when compared to other sets at £90 for 225 pieces and non genuine heads Both Nakatanenga and ourselves are site sponsors as well! Brendan |
| All times are GMT |
