Home > Td5 > TD5 rear diff filler plug
excossack
How far in should the rear diff filler plug go to be tight? I put the filler plug back in, but it felt like, if I kept going it would fall into the diff. I stopped at the plug being flush with the diff. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #229740 22nd Apr 2013 9:21pm
landy andy
They are all different.
They are on a tapered thread, so if you did keep tightening, it would fall in. They do not need to be over tight, just nipped up. If you are convinced yours needs to be tighter, but may fall in, put some PTFE on it.
Andy
Post #229748 22nd Apr 2013 9:51pm
Killer90
Site Sponsor
There not under no pressure at all so as Andy said they don't have to be wound in with a air gun Laughing do it so its flush with the diff casing and just so you get a nice little nip on it Wink Ive seen a few now which are wound in but a screwdriver soon gets it straight again Wink CSK Automotive
www.cskautomotive.co.uk
Post #229752 22nd Apr 2013 10:04pm
geobloke
Usually the plug sits just proud of the diff casing to flush with the diff casing. If however your Defender has been serviced by a Neanderthal with biceps bigger than Schwarzeneggers thighs then it is definitely possible that the plug has been overtightened.
If the plug is loose then there are a few things you can do to make it stay in place, PTFE tape works fairly well, thread lock (albeit a small amount) also works well and then there is a dab of silicone gasket sealer which is really just a stop gap in an emergency. All of the above require the threads to be as degreased as possible.
Post #229821 23rd Apr 2013 9:30am
uncas
If it looks as though the plug is going to screw all the way through the Diff pn I'd be taking a look at the threaded hole to see if it's cracked due to over tightening
Uncas
Post #230144 24th Apr 2013 12:46pm
excossack
Ive put the plug back in, and it seemed to go tight,, so to make sure it doesn't move I've put a dab of white pen on the filler plug to see if it moves. 1999 Defender TD5 110
Regards
John M0VAZ
Post #230148 24th Apr 2013 1:22pm
jst
just ptfe it if it leaks Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #230294 24th Apr 2013 10:09pm
