Home > Td5 > Front and rear diff oil - quanties
excossack
Whats the quantity of oil required for Front and Rear diffs and is it EP90? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #228879 19th Apr 2013 3:36pm
Dave-H
1.60 Ltrs
And on later Defenders its 75W/90 Synthetic gear oil, not EP 90
Smile
Edit ... Thats 1.60 ltrs per diff [not in total] Guns and Landrovers .... anything else is irrelevant.
Post #228883 19th Apr 2013 3:39pm
excossack
Cheers. That's the one, 75w/90
Time to get some on the way home Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #228887 19th Apr 2013 3:46pm
excossack
Picked up 5l of 75/90 and then found in the shed another 2.5l of the stuff!!!
Same oil as the transfer case it seems according to the Haynes manual. Well it shows MIL-L-2105 specs for both oils (75/90 for transfer case and 80EP or 90EP for axles) 1999 Defender TD5 110
Regards
John M0VAZ
Post #229343 21st Apr 2013 1:35pm
Dave-H
Yea Transfer case is the same Smile
And ... depending on who you listen to/read etc ..... so is the gearbox Confused Guns and Landrovers .... anything else is irrelevant.
Post #229417 21st Apr 2013 6:01pm
excossack
I emailed an oil company a while ago and the alternative MTF94 was a syntrax 75 oil. Handy having the same oil as the transfer case. I guess the Evo oil from another forum is 75 based oil.? 1999 Defender TD5 110
Regards
John M0VAZ
Post #229424 21st Apr 2013 6:41pm
Dave-H
I'm waivering a bit with regard to main gearbox [on the Puma], although others are happy its the same stuff Confused
Castrol's own spec sheet states BOT 130M is a fully synthetic Transmission fluid, which is not the same thing as a fully synthetic Gear oil [even if the viscosity is the same at 75W/90].....
Might just be me being too pedantic ............. Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #229502 21st Apr 2013 8:59pm
