![]() | Home > My Defender > The last of the 2.4's doing well... |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387
Nice write up, like the seats, subtle.
Love the shieldaig pic. |
| munch90 Member Since: 26 Oct 2013 Location: guildford Posts: 3558
in the pic that's shows the top of the red shock absorber , it looks like the big washer is fitted the wrong way round , the rounded side of the washer should go against the bush .
looks like flat side is fitted to inside , flat side should be to the outside not that easy to see in the pic I maybe wrong |
| Rosso_NI Member Since: 09 May 2014 Location: NI Posts: 275
Good work and tastefully modified, must admit 110 USW would be top of my list, if i was in the position to walk into a Land Rover dealer and buy a new Defender
| MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682
Thanks - I will check that. I'm sure I put them on the same way as they came off tho Appreciate all the comments, chaps |
may be worth checking the washer on the inside (chassis side ) as well
| willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789
Oops wrong thread Original Member Pie n Pea Club.
110 HCPU Tipper |
