![]() | Home > Wheels & Tyres > Front wheel removal... |
mmm...does that suggest dealer didn't bother taking that wheel off?
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Don't know if I am reading it right- I am guessing you are saying that the wheel wasn't coming away from the hub after taking the nuts off?
If so a short sharp kick to the tire normally pops it off ![]() I copper greased mine 3 years ago, and still not needed to do it again. Glyn ![]() ![]() |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
this is supposed to be done at the 2 year service!! DEFENDER 90 TDCI XS,
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 ![]() ![]() ![]() |
I had to give it about 50 short sharp kicks to get the wheel off... Really was seized to the hub.. Took longer to get the wheel off than change the brake pads! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
![]() ![]() Did they accidentally use Araldite instead of anti-seize grease?..... Then again, knowing some of the dealers out there ![]() ![]() Glyn ![]() ![]() |
