![]() | Home > Puma (Tdci) > Rear seat wont latch |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1859 ![]() ![]() ![]() |
Lube the mechanism and make sure the base is properly slammed down before locking the backrest in position.
Keith |
Helps if you try and push the release back down a ways as sometimes they don't return especially if not lubed. IIRC there is also an allen key grub screw in the mechanism under the plastic trim cover that can work loose and cause the back to lock upright too. Steve.
Greener78 Member Since: 18 Apr 2013 Location: Keswick Posts: 48 ![]() ![]() |
I just paid the local stealer an hours labour to remove a piece of plastic the size of a 1p coin from the mechanism. Part of the plastic trim had broken off. On the upside all the seats latch like new.
Might be worth popping the cover off if lubricating doesn't do the trick and see if anything is jamming the mechanism.. |
