![]() | Home > Puma (Tdci) > centre diff lock |
macduff Member Since: 04 Nov 2012 Location: NE Posts: 119 ![]() ![]() |
I could be wrong but If parked up with hand brake on and diff lock in, you shouldn't be able to rotate a front wheel when its raised off the ground, this assumes your front diff is open and subject to the normal backlash tolerances
![]() PS the other front wheel obviously needs to be on the ground ![]() |
Andy Jeff Member Since: 11 Nov 2012 Location: Suffolk, UK. Posts: 143 ![]() ![]() ![]() |
Correct. Andy. |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
cheers guy will have a look ill take it up the farm and find the forklift
![]() steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
