![]() | Home > Td5 > help with fuel pipe |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17954 ![]() ![]() ![]() |
The four pipes are:-
White - air bleed from filter back to tank. Low pressure, and shouldn't ever have fuel in it if the bleed membrane is working. Green - high pressure (c.85psi IIRC) from HP stage of pump to fuel regulator on cylinder head. Blue - low pressure feed to filter. Black (no coloured sleeve) - low pressure return from filter into HP stage of pump. I am not sure what the situation about replacement pipes for a Defender is I'm afraid, but on the TD5 Disco you can either buy a set of all 4 or the green HP pipe on its own. On the Disco it's usually the green that leaks and I think LR were getting so many warranty claims at on time (there was also a recall) that they made the green one available to save costs. A sensible repair, especially on an LP line should last indefinitely, and on the TD5 even the HP line isn't actually very HP (the actual injection pressure, generated in the head, is several thousand psi). A set of the 4 pipes for the Disco costs around £140. I know this because only today I bought a set because, after 11 years and over 200k miles, my green one has pinholed. |
