![]() | Home > Maintenance & Modifications > 110 mud flaps |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 ![]() ![]() ![]() |
Hi All,
See photos below, i already repaired this with an ali strip, but looks like it just voted through. IS the stainless brackets still available? [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] 2001 TD5 so not too bad i think ![]() Cheers Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
^^ Yes. stainless mudflap holders for the rear of a 110 are available from Offroad-Tec. I have those installed, a very good product. Below the link to the product and a picture of how they look on mine. If, like I, you would have the Entreq reinforcement brackets already installed, you probably can leave those in place and bolt the Offroad-Tec mudflap holders right on to those reinforcement brackets.
![]() Eric http://offroad-tec.de/shop/main_bigware_34...cName=body ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Thanks for that, but was wondering about the repair bracket.
Is panel repair sections available anywhere? Cheers Andy |
Do you mean just the rear mudflap holders reinforcement brackets then? Yes, available from Brendan or from Entreq.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2744 ![]() ![]() |
Just repair again with a better piece of aluminium.
Or spend £80 on some bits of metal, your call ![]() |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
To repair that, you really need a length of reasonably thick Ali angle - say 25mm x 25mm. Secure it to the inside edge of the wing with Sikaflex or similar and drill a new mounting hole.
To stop it happening again, isolate the bracket from the wing with some rubber washers on the bolt, either side of the ali. This will allow a bit of flexibility and prevent the vibrations from wearing out the mounting point. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Oops, double post. Darren
