![]() | Home > Td5 > TD5 coolant loss, at a loss... |
Ok folks I am needing the collective forum brain to help me decide what is wrong with my TD5...
Basic vehicle stats: 2002 TD5 110 with 135k miles on the clock. It has been remapped and serviced regularly. Last week I was towing our 19ft Ivor up and down the A55 to Bangor and back. The previous weekend I had done a fluid check and all was good. Yesterday I repeated the fluid check having done some pretty heavy miles to find that the coolant header tank was near as dammit empty. A scan of the engine bay did not show any obvious signs of coolant leaking from any pipework or the radiator or water pump. This has lead me to believe that the coolant only has 3 other possible ways to exit the system; 1) via a the header tank cap (although I would have expected to have seen evidence if this was the case) and 2) either the head gasket has gone or on the way to going and 3) there is a crack in the head itself and the coolant is getting out there. Without any sort of pressure tester or coolant system tester to hand I have followed these instructions on how to diagnose a head gasket failure in a TD5;
Whilst doing this I made a small film of the coolant within the header tank (I know Grammy award winning stuff this...) which I would be grateful if "the Forum Brain" could watch and tell me if there should be "NO" bubbles at all or "Some" are normal or that there are more than there should be so...?!?! To simplify the diagnosis I clamped off the radiator return pipe to stop it from confusing the situation. Please see here and comment: http://www.youtube.com/watch?v=KBnbdO-cQDc&feature=youtu.be The link takes you to a YouTube video you might as well turn the volume off as there is no funky music just the sound of a diesel engine through a bad microphone... Thanks in advance. ![]() |
Have you checked the coolant pipes that run near the offside engine mount, they have a habit of rubbing on the mount and leaking and it is not that obvious as it leaks onto the mount normally ?
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986 ![]() ![]() |
You can see plug between cylinders three and four
http://www.bing.com/images/search?q=td5+en...edIndex=36 Andy |
Thanks for the response Andy. How the heck do you check that core plug with the manifold in place?!?! Will have a delve in the morning ![]() Last edited by geobloke on 8th Apr 2013 9:36pm. Edited 1 time in total |
Hi Bob, thanks for the response. I have checked the hoses over today, but will give them another go tomorrow morning bearing this in mind. ![]() |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6021 ![]() ![]() ![]() |
You sound like you are going through what I went through with my 1999 10P TD5 engine a couple of years ago.
Coolant leak with no sign of the leak. I checked all hoses, wrapped tissue around the header tank cap, no sludge in the oil. Even got the garage to put some UV die in the water and go over it with a neon light and no sign. I tried some supersteel and that cured it for a few weeks and then went again. Ended up with pants down. a new cylinder head made by AMC and a big bill. ![]() Mine went at about 138-140k. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
appaloosadude Member Since: 17 Oct 2012 Location: Buckinghamshire Posts: 630 ![]() ![]() ![]() |
Bleed screw in top radiator hose has a tendency to fail.
Take the heat shield off the manifold (only three bolts) and you will see the pink stains (I hope) Andy |
Man alive that's a depressing story... ![]() Right I have just booked the 110 in for a sniff-test and coolant pressure test next Tuesday morning at Mcdonald Landrover. So time will tell what the test says. I did notice after a good 40 mile trip today that there was a small drop of coolant on top of the drivers side engine mount, below the fuel cooler... Seals...!??! perhaps... |
Thanks App. Roger that, looked good but will check that one and its sister screw on the bottom hose. |
Lol cheers Andy will do that once it has cooled down, just got back from a 40 mile round trip... |
£2000 is not far off, add another £68 Fingers crossed for you, that you have spotted the leak from the fuel cooler. Quick google reveals this link http://www.discovery2.co.uk/fuelcooler.html 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812 ![]() ![]() |
Check your heater pipes as well... I have had a few Td5's with leaky heater pipes (knackered jubilee clips).
Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
Thanks Ian. will do... ![]() |
