Home > Technical > Play in drive train
excossack
Play in drive train
While under the car checking for an annoying squeak, I checked the drive train for play but not sure what is too much so I took some videos
The white lines are the marks at which movement was felt
1st video, showing the whole drive train starting off with a clunk in the transfer case
The wheel is being spun by me turning the h/brake drum.
&feature=youtu.be
2nd video showing play in the h/brake drum.
3rd video showing play in the transfer case front output flange.
4th video showing play in front diff
5th video showing play in rear diff
I guess this is what you call the backlash? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #225253 7th Apr 2013 6:43pm
