Home > Puma (Tdci) > Blackbox faultmate
Apynala
Morocco 2009 Defender 110 Puma 2.4 SW Chawton White
Blackbox faultmate
Hello,
Happy to be in a Defender community.
My third def is a Puma, I use to repare my def by myself and now I would like to fit a full capacity extrem faultmate MSV-2.
I'm looking for some informations about this.
Does anyone fit it in his def.
Does anyone fit a hawkeye in his def and is it a good tool.
Thanks Thumbs Up
Post #16833 17th Oct 2009 11:38pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
I have the MSV-2 for my D3, I didn't buy the Td5 software yet as the Td5 is a very basic version no alarm, central locking, traction control, abs etc
So I wait till I really need it. So I cannot comment on the Defender software.
I like the software for the D3 and that is still under development, but can do a lot what the Dealer can't do.
The experience I have with the Blackbox is good. I had a waranty problem and that was solved good and quickly.
But what really amazed me was support on the software side. I had problem switching on satnav on the move in my D3. It worked on other D3's but mine gave a problem. Within 2 days the problem was found and a special patch was written and put on the website for downloading and this solved my problem.
Blackbox is a small company and gives you very personal service.
Their helpline is a forum and I had first my doubts about that but I am now really convinced about that as you can read the problems others had and you can get help from others solving your problem and that doesn't have to be a MSV problem but also a diagnostic or something like that. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #16850 18th Oct 2009 4:00pm
Apynala
Hello Roel,
Thank you for your reply.
I hope it's as good as i expect. I will tell you more for chrismas. If someone has more info.
Thanks a lot Thumbs Up
Post #16864 18th Oct 2009 11:04pm
mse
I conversely had really bad experiences with them for the Defender 2 - i admit it was new then - and lead to a return.
I cant decide if ill return to them, ive heard many different things, all boarder on the task the kit does is good and the other elements are bad.
If it can do what its supposed to then i may go back - its still a stressed may Mike
Post #16867 19th Oct 2009 1:07am
Apynala
Hi mse,
What was your bad experience with them, do you think that it's better for me to take the Hawkeye from bearmach?
The full capacity faultmate, if it works as they wrote, seems to be wonderfull.
What a problem Confused
Thanks for your reply
Post #16892 19th Oct 2009 6:08pm
mse
The fualtmate - technology capability wise i think would be far superior to hawkeye, in terms of capabilties.
Where i had issue with it was it didnt work and most importantly (as they were to fix it) the customer service was shocking, beyond bad...i could have waited for a fix but the attitude was very much you only spent £500 you can wait, we only make £70 on each one. Mike
Post #16897 19th Oct 2009 6:58pm
Apynala
OK,
What was your engine when you had problem with them?
Do you think that i should take a faultmate?
Thanks Thumbs Up
Post #16900 19th Oct 2009 7:50pm
mse
2.4tdci Mike
Post #16901 19th Oct 2009 8:08pm
Apynala
You don't use your faultmate on your puma, now?
Post #16902 19th Oct 2009 8:16pm
mse
I sent it back Mike
Post #16906 19th Oct 2009 8:46pm
Apynala
OK
Thanks for all Thumbs Up
I'll think about it.
I'll surely bring a diagnostic tool from France in january, (maybe) the hawkeye or (surely) the faultmate. I hope I'll have more chance.
Thanks at lot Thumbs Up
Post #16910 19th Oct 2009 9:40pm
