Home > Puma (Tdci) > battery
Page 1 of 4 1234>
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
battery
I think my battery is on its way out based on the quick voltage drop my battery monitor is showing.
Should I only worry about the cca? And if so can one fit a deep cycle with a high enough cca rating?
What is the cca of the standard puma battery?
Post #223729 31st Mar 2013 9:00pm
spudfan
Ireland
800, on the Varta battery. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #224027 1st Apr 2013 11:41pm
ZeDefender
My 2 year old battery (Puma MY11) is $hite too Evil or Very Mad Haven't run it down or anything.
One symptom is flickering LED headlamps before the engine is running. My battery resting voltage is around 11.2V (left light flickers), down to 10.8V when the glow plugs kick in (left light flickers), down to 10.2V when starting up (both lights flicker), then takes about 5 seconds to reach 14.2V once the alternator is working.
Now fitting a twin battery setup as the Varta is apparently cr@p Rolling Eyes Tell someone you love them today because life is short.
Post #224031 2nd Apr 2013 12:00am
Marius
But does it matter if it's a deep cycle I ana fit for the starting battery.......as long as the cca is above 800?
I'm looking at a Optima bluetop D31M. Whats the difference between capacity and reserve capacity?
Post #224035 2nd Apr 2013 5:42am
leeds
If it is a combined starter /leisure battery such as the Odyssey then no problem.
We run both our 110's on twin Odyssey set ups.
Brendan
Post #224040 2nd Apr 2013 7:32am
spudfan
Ireland
08 Defender still on the origional Varta and no problems whatsoever - even on the coldest of days . 1982 88" 2.25 diesel
Post #224066 2nd Apr 2013 11:44am
ZeDefender
I fear there may be quite a bit of variability depending on the year/day of week/shift of manufacture - true for the Defender and probably its parts. There's a thread running at the moment about at least 2 sets of tyres from a normally high quality manufacturer cracking at the treadblock base. I suspect they were made about the same time in early 2011. Tell someone you love them today because life is short.
Post #224083 2nd Apr 2013 1:04pm
Glynparry25
Brendan
+1 Thumbs Up , that is what I am running with no issues of any sort over the past 3 years.
Glyn Dog Sheep
Post #224101 2nd Apr 2013 2:32pm
ZeDefender
I'll soon be joining you Thumbs Up However, although I've got all the stuff ready to assemble, I'm somewhat lacking in self-confidence Rolling Eyes Tell someone you love them today because life is short.
Post #224109 2nd Apr 2013 2:57pm
spudfan
Ireland
Hope, this is not your wedding night you are alluding to. Mr. Green
Right lads who's first in with the relevant advice? Whistle 1982 88" 2.25 diesel
Post #224111 2nd Apr 2013 3:04pm
ZeDefender
Rolling with laughter
I would have taken that advice 25 years ago...now I'm too knackered to do anything with it Sad Tell someone you love them today because life is short.
Post #224113 2nd Apr 2013 3:07pm
spudfan
Ireland
Check out the Wedding night post in the Off topic section Mr. Green 1982 88" 2.25 diesel
Post #224121 2nd Apr 2013 3:38pm
BigWheels
I have this battery http://www.tayna.co.uk/Numax-CXV35MF-P8275.html Only need one. Wink Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #224272 3rd Apr 2013 12:15am
ericvv
BigWheels, that is looking good by the numbers. Is the size (LxWxH measurements) the same as the original LR Varta, meaning is it a plug 'n play replacement?
By the way, I am still running my original LR Varta, 4.5 years now, no problems except for the Speakers also flickering when the car is off, but who turns on its headlights when the truck is still not running? Thinking anyway to replace it this year before the next winter when this original Varta will have turned 5 and would like a bit higher capacity and one which keeps its charge at above 12V..... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #224278 3rd Apr 2013 5:27am
jst
i am running CXV Numax (4 sets of), all work well, and thats what will go in the Puma when it needs it. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #224284 3rd Apr 2013 6:57am
Page 1 of 4 1234>
